Crew Cab Window Switch Bezel
Old Jun 11, 2014 | 08:25 PM
  #46
Diesel_Brad's Avatar
Diesel_Brad
I am looking in the McMaster catalog for which plastic to have him make a prototype
Old Jun 11, 2014 | 09:40 PM
  #47
1993_f350_2013's Avatar
1993_f350_2013
uhmw is a good plastic and reasonable in price...
Old Jun 12, 2014 | 05:01 AM
  #48
Diesel_Brad
The McMaster catalog has a TON of different plastics in there. I just ordered a 1"x 3" x12" block for $14 Have to see how it works, If not I will try something else
Old Jun 12, 2014 | 09:02 AM
  #49
LeoJr's Avatar
LeoJr
Originally Posted by Crewcabber
I have a guy I'm going to see tomorrow about machining them out of aluminum
I suspect that getting the texture correct will be a challenge in plastic or aluminum.
I had to machine an area on cast aluminum part and it stood out as very obvious. I used a welder's needle gun, one that had been used a while and the needles weren't too pointy, to roughen up the machined area. It took a little practice to work it enough, but not too much. But the end product looked almost perfect.
This may help give a machined aluminum piece some texture. I like a billet look for some things, interiors is not one. Just my opinion.
Old Jun 12, 2014 | 09:20 AM
  #50
DIYiT's Avatar
DIYiT
For texture, maybe sand blasting or a spray on coating of some sort would work well. Then you could also spray the other trim pieces in the same manner so that they have an uniform look.
Old Jun 12, 2014 | 09:28 AM
  #51
Diesel_Brad
Hopefully the cutting process can leave some texture.
I do NOT want to have to coat it with something, only to have it wear off
Old Jun 12, 2014 | 09:34 AM
  #52
Crewcabber's Avatar
Crewcabber
As far as finished aluminum piece I agree unless you had some other pieces to tie all together the door bezel would look our if place. A powder coat finish would give them a nice texture and last forever . An anodized finish would be smooth but still better than. The billet look.
Old Jun 12, 2014 | 09:50 AM
  #53
Diesel_Brad
I would Not say powder coat would last forever
Old Jun 12, 2014 | 10:14 AM
  #54
Crewcabber's Avatar
Crewcabber
True not forever but for the wear and tear that the bezel would see it would pretty damn long you would send that truck to jy or sell it before you had to resurface it again.
Old Jun 12, 2014 | 11:52 AM
  #55
Diesel_Brad
You also cannot powered coat plastic. It has to be some sort of metal. So the metal costs more to begin with then also add in the power coat.
Don't get me wrong, aluminum will never brake and that was my 1st idea, but cost is a big factor.
The cheapest aluminum bar stock I found is $24 for a 1" x3" x 12". So almost double the price to begin with. Then the bits cot cut aluminum are more expensive than ones to cut plastic, so that is more expensive. The time to cut aluminum i THINK is more. Then also factor in powder coat
Old Jun 12, 2014 | 12:11 PM
  #56
Crewcabber's Avatar
Crewcabber
Yes sir they would be more expensive we discussed that on the first page of this thread
Old Jun 12, 2014 | 05:17 PM
  #57
SteelHorse4x4's Avatar
SteelHorse4x4
Hey guys, just trying to work the eye a little and was looking through the thread. One thing to consider, if I missed it I'm sorry, but maybe take it to a 3d printer company. They literally could 3d scan it, then print out a new one. Just a thought.
Old Jun 12, 2014 | 06:27 PM
  #58
Crewcabber's Avatar
Crewcabber
What's up steel that was discussed on the previous page, thanks for the input.
Old Jun 12, 2014 | 08:43 PM
  #59
joshh's Avatar
joshh
just a thought to cut down on maching cost remember all that void in the back side dont actually need to be cut out mine is 1/2" thick with just switch holes and screw holes machined out the voids make the injected part cheaper is why they are there
( wish i could get the cad file from when mine was cut but have no idea who actually did it my buddy had it made before i bought the truck )
Old Jun 12, 2014 | 08:52 PM
  #60
Diesel_Brad
The bezel needs to be 1" thick(15/16 to be exact) for it to fit the door panel correctly and have the switches mount
