Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford 477 starter
Old Jun 5, 2014 | 12:07 PM
76f250460's Avatar
76f250460
Ford 477 starter
Im trying to get my 68 F850 to run, it has the 477 engine. The starter is bad. Where is a place where i can find a new one, and will one off a 534 work. Or is there also a way to rebuild the starter.
Old Jun 6, 2014 | 12:05 AM
85e150's Avatar
85e150
You mentioned air brakes in another of your threads. Have you inspected the linings, cans, lines and tanks?
As for the starter, why do you think it's bad?
Do you have an auto electric shop near by? They would rebuild starters or may be able to swap you out with a reman.
You might also try Napa, but you'll have to explain what you are doing or they will get you a starter for an F350. Some stores are better for trucks like this than others.
So this was not running when you bought it?
What are the tires like?
What is the GVWR?
Old Jun 6, 2014 | 02:51 AM
big job's Avatar
big job
I'll check on the starter for ya (nothing special with those) been awhile
since I set my butt in one of those, but my mind is seeing a three bolt
Bendix style. Strong chance it needs a good cleaning. My mind sees
a typical 430 Lincoln Mercury starter, which we use to say those 477 534s
were blow out 430s where as the 401 534 were derived from....
I got the genuine books on these I'll check.
sam
Old Jun 6, 2014 | 08:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B8QH-11002-A .. Starter Assy (Motorcraft SA-68) / Obsolete
1958/77 F850/1000 401/477/534.
GRIESEL MOTOR CO. in Okarche OK has ONE = 405-263-7242.
srqdiesel chef
May 27, 2009 09:29 PM
sckootter16
Oct 13, 2008 03:32 PM
Martin Broll
Oct 29, 2007 12:24 PM
rocco913
Aug 17, 2007 08:22 PM
