harmonic balancer removal question
Old Jun 4, 2014 | 04:54 PM
jps47's Avatar
jps47
I am installing a melling lpop and can't get the nut to budge on the balancer. in the instructions It says to put in low gear and have at it. I did that and the truck just went backwards under me so I blocked the wheel cause my e-brake wasn't holding enough. It says turn counter clockwise, what am I missing it just continues to turn under the compression of the motor. Its a stick
Old Jun 4, 2014 | 07:20 PM
F350-6's Avatar
F350-6
I believe the easiest way to remove the bolt is to use a long breaker bar and brace it against the frame or ground. Unplug the CPS while you're under there getting it all situated.
Then bump the starter with the key and the bolt should come right out or be loose. Unplugging the CPS will make sure the truck doesn't accidentally start.
Old Jun 4, 2014 | 08:55 PM
jps47's Avatar
jps47
got it used pry bar wedged between 2 bolts from puller, on and off.
f-250diesel
Dec 28, 2009 12:16 PM
84 f250 6.9
Nov 25, 2009 10:53 AM
tndiesel
Jul 18, 2007 04:49 PM
Mopey
Apr 4, 2005 10:59 PM
bigwhtbco
Jul 3, 2004 08:16 AM
