Inside Door Handle
Old Jun 4, 2014 | 03:41 PM
Marty69F250's Avatar
Marty69F250
Inside Door Handle
So today I was replacing the outside drivers door handle on my 1969 CS. All was going well until I went to reinstall the inside door handle. It turns out that the two small studs (3/16) that you slide the inside door handle over and secure with the 2 small nuts are essentially stripped or threads worn flat from the handle being loose at some point. Anyone have any suggestions on a quick fix? I was wondering about wrapping the threads with aluminum foil to see if that would help the nuts grab or maybe using steel wool. ....... ideas??
Old Jun 4, 2014 | 03:52 PM
MIKES 68 F100's Avatar
MIKES 68 F100
LMC SELLS A NEW PIECE LIKE $20 just saw it flipping thru their catalog yesterday
Old Jun 4, 2014 | 04:28 PM
Marty69F250
I will have to check with LMC...thanks!.....any tips or tricks in the meantime though?
Old Jun 4, 2014 | 08:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It turns out that the two small studs (3/16) of the door lock remote control that you slide the inside door handle over and secure with the 2 small nuts are essentially stripped or threads worn flat from the handle being loose at some point.
C8AZ-6221819-B .. Left Door Lock Remote Control / Obsolete
1968/72 F100/750 / 1968 Bronco from serial number B96,001, ditto 1969/72 / 1969/72 Econoline // 1968 Galaxie/LTD.
1968 Fairlane/Torino/Falcon/Comet from 9/25/67, ditto 1968 // 1968 Thunderbird from 9/25/67, ditto 1969/71.
Old Jun 4, 2014 | 10:58 PM
Marty69F250
Thanks for the part number NumberDummy...that will help. I was able to get it tight today by sort of cross threading a different nut. I obviously need to get a new or good used one.
Old Jun 5, 2014 | 09:13 AM
MIKES 68 F100
i'd just order part and roll window down and open from outside handle till part comes in
Old Jun 5, 2014 | 10:18 AM
orich's Avatar
orich
Put that handle bracket on your Pick n pull JY list of goodies to look for the next time your visit one..
Orich
Titanic II
Oct 25, 2014 12:49 PM
fordman75
Jun 9, 2014 09:21 AM
RetiredWilly
Oct 28, 2013 05:44 PM
flying4fish
Apr 27, 2013 12:34 PM
Adamjr
Sep 22, 2009 06:25 PM
