Transmission Problems
Old Jun 3, 2014 | 06:43 PM
TussockyWater's Avatar
TussockyWater
Hi,
I have a 2000 Ford Excursion with multiple transmission symptoms, so here goes.
The problem doesn't occur until after the vehicle has been driven approximately 100 miles as far as I can tell. At that point, I'll start to notice smoke coming from underneath the vehicle caused by the transmission leaking fluid onto the exhaust from the front of the transmission. At lower speeds, and while idling, the transmission will shake and shudder. It's not noisy or that extreme, but definitely noticeable. I've also noticed on occasion there is a loss of power at higher speeds when the vehicle is in 4th or 5th gear. This mostly happens when trying to accelerate to pass on the highway. The transmission sounds like it downshifts, but the hard I push the gas pedal, the less power I have. If I push down far enough, the RPM's begin to drop. I've noticed that after I let the vehicle sit turned off for a couple of hours, it begins to work properly again, but it only lasts until the transmission is hot again.
Any suggestions or ideas as to what this might be, would be appreciated. Thanks.
Old Jun 3, 2014 | 06:44 PM
TussockyWater
Also, the check engine light has recently been coming on when the problem occurs.
Old Jun 3, 2014 | 07:03 PM
02expy's Avatar
02expy
get the codes checked and see what it says.
also I would pull the pan and see what evidence is in it... sounds like the front pump is leaking but could be much worse
Old Jun 3, 2014 | 09:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You don't have a problem in 5th gear. You only have a four speed transmission, there is no fifth gear. The torque converter will lock, which does feel like another gear.
I agree that you need to get the codes read to be able to diagnose this. Don't take it to an auto parts store, they can't read all of the codes that you need.
valenrandy
2004 - 2008 F150
21
Jun 5, 2017 05:16 PM
bob0312
Apr 16, 2010 02:25 PM
SuperDoodie
Jun 9, 2008 11:37 AM
tbarn
Oct 11, 2006 11:58 PM
dbacklund
1983 - 2012 Ranger & B-Series
Nov 13, 2004 07:55 PM
