Yes, you should be covered under two different scenarios:
One- the 5yr/60k powertrain warranty.
Two- If I remember correctly, dealer repairs are warrantied for 12mo/12k miles. Check your service invoice fine print to be sure, but I think I'm right on those numbers....
Make sure your service department goes over the system with a fine tooth comb, there's no reason you should be experiencing this again so soon after the initial repair
FWIW, warranty repairs do not get extended the 12/12,000 dealership repair warranty if the original repair was made under the original truck warranty. Strange but true.
The 12/12,000 dealership warranty extension is only if paid out of pocket repairs.
