I have a 2004 f350 with a 6.0 the truck only has 55000 miles on it I got a check engine light for under turbo boost can anyone tell me what to look for Iam just learning about the 6.0
What DTC # was it ? A gauge would be helpful like Bizmic has said, have you Inspected the CAC boots for splits ? MAP hose too, you can pull the Threaded Nipple at the Intake and clean up the soot build up the little hole gets clogged.
Check the EBP and tube, pull the tube and make sure its free flowing, the sensor just make sure the little hole is not blocked , you can also have some one tap on the sensor while you watch the Scan Gauge on EBP if it jumps around then change sensor out.
