Power Steering Issue- I'm Stumped!
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_122353_zpsmuoiticv.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_122353_zpsmuoiticv.jpg" border="0" alt=" photo IMG_20140601_122353_zpsmuoiticv.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_122410_zps2hdhmddl.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_122410_zps2hdhmddl.jpg" border="0" alt=" photo IMG_20140601_122410_zps2hdhmddl.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_122518_zpsqrj5cfp5.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_122518_zpsqrj5cfp5.jpg" border="0" alt=" photo IMG_20140601_122518_zpsqrj5cfp5.jpg"/></a>
This is my makeshift cap, the connection to the right feels loose. I can wiggle it around a bit, not sure if that is normal
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_122722_zpsmfnompls.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_122722_zpsmfnompls.jpg" border="0" alt=" photo IMG_20140601_122722_zpsmfnompls.jpg"/></a>
This is the possible leak spot I found.
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_122852_zpsulmea8ay.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_122852_zpsulmea8ay.jpg" border="0" alt=" photo IMG_20140601_122852_zpsulmea8ay.jpg"/></a>
These are the unknown pieces I found in my driveway, not sure what they go to
I would suggest cleaning/degreasing the parts you suspect are leaking, then top off the fluid and check for leaks both while running and not. It's possible that it leaks everywhere you indicated, but at least you can figure out the worst leak right away.
Check your cab/body mounts and your suspension for missing/broken pieces that would cause the body to shift.
Take a flashlight and look closely at the frame -make sure that there isn't any rust thru nor cracks.
Then I would carefully jack up the truck and see if there is articulation of the frame anywhere.
The rubber is cracked here
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_192302_zpszzwy2fyn.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_192302_zpszzwy2fyn.jpg" border="0" alt=" photo IMG_20140601_192302_zpszzwy2fyn.jpg"/></a>
More cracked rubber
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_192330_zpskprin4ry.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_192330_zpskprin4ry.jpg" border="0" alt=" photo IMG_20140601_192330_zpskprin4ry.jpg"/></a>
This is for sure the spot where the fluid leak is coming from
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_192415_zpswnstrgxv.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_192415_zpswnstrgxv.jpg" border="0" alt=" photo IMG_20140601_192415_zpswnstrgxv.jpg"/></a>
Here is a zoomed out picture to show where all of these are located
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_192601_zpsjetcdvme.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_192601_zpsjetcdvme.jpg" border="0" alt=" photo IMG_20140601_192601_zpsjetcdvme.jpg"/></a>
So is it possible the parts that have the cracked rubber pieces could have caused any of this and need replaced? If so, what are they called? Also, what is the name of the part where the leak is coming from? I'm assuming that for sure needs to be replaced. Sorry for not knowing what any of these parts are called, hopefully the pictures will help.
Post up some pics of the frame on the outboard side of the steering gear, suspension, and other cab mount points. There may be clues there you aren't aware of that someone here can recognize and suggest a way to fix it.
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_202405_zpsbcv5xxqe.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_202405_zpsbcv5xxqe.jpg" border="0" alt=" photo IMG_20140601_202405_zpsbcv5xxqe.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_202537_zps13wref38.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_202537_zps13wref38.jpg" border="0" alt=" photo IMG_20140601_202537_zps13wref38.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_202701_zpsd4b4jpzs.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_202701_zpsd4b4jpzs.jpg" border="0" alt=" photo IMG_20140601_202701_zpsd4b4jpzs.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_202905_zpsyuqetkq6.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_202905_zpsyuqetkq6.jpg" border="0" alt=" photo IMG_20140601_202905_zpsyuqetkq6.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_203109_zpsh5gbfxra.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_203109_zpsh5gbfxra.jpg" border="0" alt=" photo IMG_20140601_203109_zpsh5gbfxra.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_203554_zpscnhbh7w0.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_203554_zpscnhbh7w0.jpg" border="0" alt=" photo IMG_20140601_203554_zpscnhbh7w0.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_203712_zpshnwc49em.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_203712_zpshnwc49em.jpg" border="0" alt=" photo IMG_20140601_203712_zpshnwc49em.jpg"/></a>
<a href="http://s1302.photobucket.com/user/BigBodySage/media/Mobile%20Uploads/IMG_20140601_203737_zpspoe9zjjc.jpg.html" target="_blank"><img src="http://i1302.photobucket.com/albums/ag136/BigBodySage/Mobile%20Uploads/IMG_20140601_203737_zpspoe9zjjc.jpg" border="0" alt=" photo IMG_20140601_203737_zpspoe9zjjc.jpg"/></a>
There are some more pictures, not sure if any of them are useful though. I was doing some researching, is it possible that my front end just needs an alignment? I know I need to replace the steering gear box to fix my leak, but is it possible the alignment is off and that is why my tire is so close to my bumper? If so, could that have put too much stress on the pitman arm and cause my gear box to leak?
The good news is it's a F-250 with a bit more frame to work with --- if this were a F-150, we'd be looking at a new frame or extensive welding/reinforcement.
