Factory Amp Pics
Old Jun 1, 2014 | 12:09 PM
Konabro2's Avatar
Konabro2
Factory Amp Pics
Can somebody post a pic or 2 of what the factory amp looks like in our trucks?
I drive a 96 ford f250 and according to a local car audio place they are blaming my factory amp for some sound issues I'm having with trying to install an aftermarket deck but I don't think they truly know what they're talking about. I've tried looking for the amp and I just don't see it and I'm beginning to think I don't even have one. I've read it's located up and right of the gas pedal but the car audio place said Its behind my dash and would be very difficult to get to??
Thanks for the help.
Old Jun 1, 2014 | 12:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
what type radio did your truck have, a premium sound system, or just an AM/FM cassette?
as far as i remember, the pickups were not made with the premium sound system, only the generic am/fm cassette player. and that was an all in one unit with no external amp. the external amp was a premium sound system thing.
Old Jun 1, 2014 | 12:38 PM
Jarryd's Avatar
Jarryd
I'm gonna go on a limb here and say they don't have a clue. I had no trouble at all installing my stereo with generic parts from best buy. Even with an amp there's not anything to it. Sometimes you need a resistor, that's about it.
Old Jun 1, 2014 | 02:32 PM
Konabro2's Avatar
Konabro2
I see no evidence of a premium sound system. My factory deck is an AM/FM cassette and I have no sub, just 4 speakers (2 in the door and 2 in the rear corners of the extra cab).
Old Jun 1, 2014 | 02:40 PM
eakermeld's Avatar
eakermeld
Go to another audio shop. Those guys will cause you nothing but problems. They are already finding reasons why it won't work/doesn't work, not trying to resolve the issue.
Old Jun 1, 2014 | 02:43 PM
Diesel_Brad's Avatar
Diesel_Brad
Only the premium systems got the amp(Factory CD player)
If you have one it is plainly obvious above the gas pedal
Old Jun 1, 2014 | 02:45 PM
Konabro2's Avatar
Konabro2
The guy I worked with at the audio place seemed to be full of bs. He claimed it was the factory amp that was not allowing sound to get to my speakers. He also told me it was a negative polarity system??
Well the next day I sat working on it and trying to figure it out and I got it to work great but only when the sound is faded to the rear speakers. When the sound goes to the front it stops and I get nothing??
Any ideas? My next step is going to be to pull the door panels and see if there is an issue with the connections especially the (-).
Old Jun 1, 2014 | 02:46 PM
tjc transport
i ain't rite
a stock stereo than.
you don't need them, just buy the radio you want and get an adapter kit to fit it and your truck.
here is the wiring pin out:
The Install Doctor - The Do-It-Yourself Car Stereo Installation Resource - Quick Wiring Section - Radio and Stereo Wire Colors
Old Jun 1, 2014 | 02:47 PM
Konabro2's Avatar
Konabro2
I have the correct connections.
The factory stereo plays great when connected to all 4 speakers.
The aftermarket deck will only play to the rear speakers.
Old Jun 1, 2014 | 03:08 PM
Eddiec1564's Avatar
Eddiec1564
The best thing to do, is run new speaker wires to each speaker. I think the problem you are having is the head unit is a floating ground speaker output and the factory is usually a common ground through the wire harness.
Some high powered head units/amps do not like a common ground setup. You can smoke your head unit/amp with common ground setup!
Old Jun 1, 2014 | 03:15 PM
Konabro2's Avatar
Konabro2
What if I just replace the speakers? Won't that also do the trick?
They are 17 years old!
Old Jun 1, 2014 | 03:39 PM
Diesel_Brad
Right there says it all. Sounds like the aftermarket radio is the problem
Old Jun 1, 2014 | 03:44 PM
Konabro2's Avatar
Konabro2
According to the car audio place, they tried a 2nd aftermarket deck with the same result.
To be more clear, I will get sound from anywhere from a couple seconds to a couple minutes. Maybe it'll cut out on its own or I'll hit a bump and stops. When the sound is faded to the back I have no issues and it works perfectly.
Old Jun 1, 2014 | 04:15 PM
Diesel_Brad
Just to be clear. The stock radio put good sound out to all 4 spears with zero problems?
Old Jun 1, 2014 | 04:25 PM
Konabro2's Avatar
Konabro2
Correct. Factory stereo put out sound to all 4 speakers with no issues with going out at any point of driving.
