modding an aod transmission pan.
Old 06-01-2014, 12:35 AM
ecco72's Avatar
ecco72
ecco72 is offline
May have to take off the pan of my aod again due to tv issues after replacing the trans. Has only first and reverse right now. Could I add a magnet in the bottom and or a drain plug without effecting it's operation?
Old 06-01-2014, 08:42 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,170 Likes on 925 Posts
I see no issues with adding a magnet or magnetic drain plug.
Old 06-01-2014, 09:02 AM
Conanski's Avatar
Conanski
Conanski is online now
What is the full story here? Did you do an engine swap perhaps or was this a stock truck before the trans work?
Old 06-01-2014, 09:09 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
Sounds like a Direct Clutch, stuck governor, valve or TV issue......the magnetic drain plug is a plus but won't catch everything as some worn items are not magnetic
Old 06-01-2014, 09:24 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I'm gonna throw it out there that the tv is too much. It won't shift out of 1st because it thinks you got the pedal mashed to the floor all the time.
Need conanski's question answered also.
thbowen
04-24-2009 06:02 PM
kawa
15
03-11-2008 07:52 AM
51dueller
06-15-2006 04:25 PM
Cor
08-17-2004 04:04 AM
z 97ford1
1997 - 2003 F150
10-15-2003 11:43 AM
Quick Reply: modding an aod transmission pan.
