Turbo questions
Old May 31, 2014 | 04:15 PM
OldBlack4x4's Avatar
OldBlack4x4
Turbo questions
So I am planning on rebuilding my turbo and have a couple of questions. Number one which brand turbo kit is best? What have you guys had success with? Second I was thinking about moving to a smaller 1.0 compressor housing. Any thoughts on that? And lastly my compressor wheel as I'm kinda at a loss to which wheel to get anyone have any suggestions? Thanks for all the input
Old May 31, 2014 | 04:46 PM
427 fordman's Avatar
427 fordman
I think Clay at Riffraff has a new wheel with some good reviews, supposed to work well. I'm pretty sure he can help you with everything you want. Email or call him, he's a good guy. When I had my stock turbo I got a kit from Ron's turbo, another good place. I would recommend getting the turbo balanced when you do the rebuild. I sent my parts in to Ron's for the balance, just had to pay return shipping.
Old May 31, 2014 | 05:51 PM
fordpride's Avatar
fordpride
Old May 31, 2014 | 09:22 PM
Chris56ford's Avatar
Chris56ford
lost
I have a 1.0 turbine housing and Clay's (RiffRaff Diesel) billet wheel and I love the combo on stock injectors. Here is my thread on the wheel.
I wouldn't do the 1.0 housing unless you have and are going to stay with stock injectors for a while. I think stage 1s might be OK but EGTs would get really high in the upper rpm range (3k+). The 1.0 housing effectively lowers your powerband within the rpm range so you don't have to have the motor singing at 3k+ to get the power you need. (It builds boost much faster)
There is a lot of people that will say not to do the 1.0 housing because of higher EGTs. I actually found the opposite on stock injectors up to about 3100rpm, then EGTs did seem to get higher but the power isn't at that rpm range anymore anyway. I found it had more power and lower EGTs up to about 3100rpm. I have about 10k heavy towing miles on my 1.0 housing without the IC and another 5k with the IC. It works great towing.
It is a great upgrade with stock injectors. It might not be a wise upgrade if you plan on doing bigger injectors in the near future.
RiffRaff Diesel is IMHO the best place to buy parts, Clay has the best customer service I have ever seen, he will take care of you and his prices are great too.
Old Jun 2, 2014 | 10:45 AM
trykillthis's Avatar
trykillthis
If you are going to rebuild it, don't get the garret rebuild kit, get the one from Barder Turbo Service with the upgraded 360* Thrust bearing. Roughly same price and better support over stock.
akcooper9
42
Jun 8, 2017 04:48 AM
Meydawg51
37
Mar 17, 2015 08:09 AM
jr2000sd
34
Mar 12, 2015 03:42 PM
clux
84
Dec 10, 2014 04:49 PM
90pioneer
Jun 29, 2014 12:41 AM
