fuel gauge not working
Old May 31, 2014 | 10:14 AM
imjwm's Avatar
imjwm
I'm trying to figure out what I'm going to do. The gauge for my front tank does not work but I can get fuel out of it. The back tank is starting to leak. I don't have much money but am also thinking of putting in a sump and maybe a lift pump. Any one have some recommendations?
Old May 31, 2014 | 10:59 AM
farmert's Avatar
farmert
Need a little more info, does the gauge work when you switch to the rear tank? Does the front tank show full or empty? If the front tank show empty all the time, it may be just a bad float. If the truck won't switch between tanks, check the in cab fuses, #5 IIRR.
Old May 31, 2014 | 12:52 PM
imjwm's Avatar
imjwm
The switch works fine and the gauge works when it is on the rear tank. But it shows empty when on the front tank.
Old May 31, 2014 | 01:31 PM
farmert's Avatar
farmert
Being the gauge works on the rear tank, I would check the float in the tank, and the wires going from the selector valve to the tank.
Old May 31, 2014 | 03:29 PM
madpogue's Avatar
madpogue
What's with the sump / lift pump idea? You can, for the time being, just "gauge" your fuel consumption on the odometer. The only catch is, to drop the front tank, you'd want it as close to empty as possible, which means you want to run it down and then switch to the rear tank and run on it while you're fixing the float in the front.
What might be a better strategy is to replace the rear tank first, so you always have one tank to run on. The Spectra F1G is on sale for $66 and change right now on Amazon, free shipping. That gives you the option of running the front tank dry to make it easier to remove.
As for the front, if it's just the float, you can find it separately and weld it onto the arm of the sender. If it's the whole sender, those are actually the most expensive part of the whole affair.
Just for grins, try this - disconnect the wire connector going to the front tank, where it joins the main harness on the frame. Then turn the key on and watch the gauge. If the gauge pegs past full, then the problem is indeed somewhere between that connection and the tank, probably a fuel-logged float as mentioned above.
Old Jun 3, 2014 | 02:12 PM
imjwm's Avatar
imjwm
Thanks for your input. The thing with the sump and maybe a lift pump is that I was thinking of maybe doing some of those things while I'm messing with the fuel stuff. I guess my question is what do you have to before you need a lift pump?
Old Jun 3, 2014 | 02:22 PM
madpogue's Avatar
madpogue
Your question is still not clear. Is there something wrong with your existing fuel (lift) pump? If so, it has nothing to do with the gauge or floats. If the gauge is working on one tank, and the selector is switching tanks properly, then that leaves the float or sender itself for the non-working tank, or the wiring to it.
Old Jun 3, 2014 | 02:23 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
The lift pump is on top of the motor. If it's working fine I would leave it be.
Old Jun 3, 2014 | 02:32 PM
imjwm's Avatar
imjwm
Well I was taking about something like an air dog but I think I'm going to hold off on that for now.
Old Jun 3, 2014 | 02:43 PM
madpogue's Avatar
madpogue
That ^^^^ would be downstream of the selector anyway, so again, no relation to the senders, selector, gauge, wiring, etc.
AKHunter93
Jun 6, 2015 06:47 PM
jerwiltho
Feb 20, 2013 02:12 PM
Revmitchell
Jan 30, 2011 01:03 PM
Hunt4Fun
Nov 30, 2007 07:44 PM
PhilcoPGM
Sep 17, 2005 07:26 PM
