transmission
Old May 29, 2014 | 11:50 PM
lemasters f100's Avatar
lemasters f100
transmission
So I got all the bell housing bolts off and unhooked from the support bar and the trannie still is not coming undone??? What am I missing??? C6
Old May 29, 2014 | 11:56 PM
HIO Silver's Avatar
HIO Silver
Shift linkage, cooling limes, speedo cable, starter, tq convertor to flex plate nuts, drive shaft.
VocaTexas's Avatar
VocaTexas
Did you unbolt the torque converter from the flexplate?
Old May 29, 2014 | 11:59 PM
EP145's Avatar
EP145
Torque converter nuts... There is a cover in front of the transmission with 4 or 5 studs that stick thought the flex plate you need to rotate the engine over and unscrew the nuts.
Old May 30, 2014 | 12:17 AM
lemasters f100
I've done that too
Old May 30, 2014 | 12:19 AM
lemasters f100
Yes I did.
Old May 30, 2014 | 12:22 AM
lemasters f100
I've got all that off yet it won't drop.
Old May 30, 2014 | 12:44 AM
Ford59galaxie's Avatar
Ford59galaxie
Does it pry apart at all? As long as you have all the previously mentioned items removed it should pull right off. You might have to jack up the back end of the transmission to remove pressure and pull it straight back a few inches because 1) the torque converter studs might be binding on the flex plate and 2) Oftentimes there are guidance studs about 3 inches long driven in the back of the engine block that could cause binding.
Old May 30, 2014 | 01:03 AM
EP145's Avatar
EP145
Originally Posted by lemasters f100
Yes I did.
Hmm that sucks...
520SC
May 31, 2017 10:55 PM
Tomget
Jul 27, 2012 11:54 AM
aerocolorado
Jan 5, 2012 01:21 AM
kcode
13
Nov 20, 2011 08:08 PM
oldmantwinter
Jul 25, 2003 10:30 AM
