Help with ICP Volt values please
Old May 29, 2014 | 08:15 PM
RideDiesel88's Avatar
RideDiesel88
We'll I replaced my head gaskets with complete success. It took about four 8 second cranks and it fired right up as I watched icp build on scan gauge. It drove fine maybe a little rough for the test drive then the next couple days it ran smooth as can be. 100 mile trips each day. A couple days ago my CEL came on for p2285 icp low circuit. So I cleared it and it came back yesterday. My ICP ranges beautifully 650-1200 and my ICP volts seem to be fine .89 .91 at idle and 1.5-2 and IPR ranges fine too 22-40. This didn't happen before I did the head gaskets. I actually didn't even know where my cel was this whole time I've owned my truck til now. The wire harness was pull all the way out to the radiator when I did the work I don't know why I didn't inspect it. I also have a slight vibration while accelerating, don't know if this could be a symptom of a bad sensor. Are my ICP volts supposed to be higher?
Old May 29, 2014 | 08:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Possibly a bad sensor or connector.
Try driving with the ICP disconnected and see if the vibration clears upon acceleration.
JOsh
Old May 29, 2014 | 09:06 PM
RideDiesel88
Will do. But it started after the hg job and icp volt values seem good right?
Old May 29, 2014 | 09:11 PM
Bullitt390's Avatar
Bullitt390
ICP values look great, but the sensor could still be bad.
What does it read @ KOEO?
I would try:
Driving with ICP unplugged, improved inspect harness or replace sensor
No improvement:
Unplug EBP sensor and drive:
Improved? Same deal as ICP.
No improvement?
Inspect MAP hose and intake adaptor
Josh
Old May 29, 2014 | 09:16 PM
9228.bobcat's Avatar
9228.bobcat
May want to check your exhaust as well. Make its not hitting anything.
RideDiesel88
Jan 28, 2015 07:30 PM
patrick77598
Oct 30, 2013 06:51 AM
joegebff
17
May 2, 2013 05:50 AM
TNT in Round Rock
Jan 24, 2012 03:58 PM
Sparkplugless
36
May 22, 2009 05:52 AM
