Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F800 Fleet , Need Help
Old May 28, 2014 | 06:31 PM
outboard225's Avatar
outboard225
I need some professional knowledge on these trucks. I have acquired 3 f800's. Seems there is not a dealer in my area that offers a lot of help with them. All have 5.9 cummins. 1997,1999 models. Im in Raleigh NC if anyone is close. If there is a guru local I will pay for your time just to counsel me on these trucks.
1 problem with all three
Antifreeze in crossmember under the radiator? There just seems to be a puddle there all the time. Is this the plastic tank? I know they seem to crack.
2nd problem is the hydraulic brakes.
Not sure if the system is up to par. Seems like we have to push on the peddle hard to get stopped on these trucks. The one with air brakes stops like a dream.
Old Jun 10, 2014 | 11:23 AM
69 F-350 Wrecker's Avatar
69 F-350 Wrecker
Since no one has responded, I'll jump in with my 2 cents. Look for a good local independent shop. I'm a little too far from you to recommend one, but you may have better luck finding one on the outskirts of Raleigh. You may want to check with some local Big Truck Junkyards for a good recommendation.
Bill
Old Jun 10, 2014 | 02:01 PM
jpr38057's Avatar
jpr38057
Is the coolant there after sitting overnight or after driving? Could be cold water leaks if you find it after sitting.
riverslandscaping
Large Truck
Apr 10, 2018 05:51 PM
gelato583
6.7L Power Stroke Diesel
Nov 6, 2012 09:54 AM
14psd
Sep 24, 2009 08:58 AM
just another truck
28
Jan 28, 2008 01:47 PM
