what is this plug
Old May 28, 2014 | 11:12 AM
davidwjacob's Avatar
davidwjacob
what is this plug
Hello all,
can someone tell me what the plug is in this pic? 1991 f350 7.3 idi
Thanks
Dave
Old May 28, 2014 | 12:39 PM
jas88's Avatar
jas88
That's a MAP sensor for a gas truck. If you are sure your truck has always been a diesel, perhaps somebody put an evap case on it from a gas truck?
Old May 28, 2014 | 12:40 PM
davidwjacob
thanks for the info, ill look into it
Dave
Old May 28, 2014 | 01:52 PM
jas88's Avatar
jas88
I see a big vacuum leak in your pic, btw.
Old May 28, 2014 | 01:53 PM
davidwjacob
Thanks, but that pic was taken while i was replacing the vacuum pump , if your talking about the vacuum line missing off the black plastic connector in the upper right of the pic. if not then please tell me what you see.
thanks
Dave
Old May 29, 2014 | 07:19 AM
jas88's Avatar
jas88
Yes that is what I am talking about.
Old May 29, 2014 | 07:56 AM
helifixer's Avatar
helifixer
that is a "map" sensor but on the non turbo diesels they read barometric pressure. all that I have ever worked on have a wiring harness connected to it (might be for automatic transmissions only? )
Old May 29, 2014 | 08:10 AM
Chevy_Eater's Avatar
Chevy_Eater
Turbo or not the IDI never had an ECM therefore never had a MAP sensor. Jas is correct, either the truck was converted to IDI or the A/C box was swapped out with one from a gasser.
Old May 29, 2014 | 09:45 AM
davidwjacob
Thanks man, yeah i was in the middle of replacing my vacuum pump when i snapped that shot, and that was the main hose from the pump.
Thanks Anyway, i am new to all this, so if anyone see's anything please hit me up. That was my first vacuum pump, it went smooth, although i know nothing else will.
lol
Dave
davidwjacob
ok thanks for the info guys
Dave
Old May 29, 2014 | 10:35 AM
jas88's Avatar
jas88
helifixer's post got me to thinking so I did some research. I have misled you. That is a MAP sensor but I thought they only went on gas trucks. However, it seems the auto trans-equipped diesels have them too. It is true that the IDI does not have an ECM, but the E4OD trans does have an ECM, and it must be reading barometric pressure using the MAP sensor (MAP stands for Manifold Absolute Pressure, in a gas truck it would have a vacuum hose hooked up to it). Here is a pic from an auto-trans equipped diesel truck on eBay:
Sorry for the misinformation, all my diesels have had manual transmissions, so I have never seen this sensor on a diesel before. Now you gotta find out where the wiring harness that plugs into it has gone to!
Old May 29, 2014 | 12:34 PM
Chevy_Eater
I don't understand that though, what would a transmission need a MAP sensor for?
I'm fairly certain (not 100% though) that my E4OD didn't have that and I spent way too much time on the POS and it's wiring. Truck's long gone though so I can't verify.
I'll keep an eye open in the bone yards though...
Old May 29, 2014 | 02:04 PM
davidwjacob
JAs88,
there is still something strange going on here as this truck is a 5 speed manual
Dave
Old May 29, 2014 | 03:08 PM
jas88's Avatar
jas88
When you say "this truck" I assume you mean your truck? Maybe it's been converted from auto trans? What is the trans code on the door sticker?
In any case, if your truck is manual trans now, you can just take that MAP sensor off and toss it.
Old May 29, 2014 | 03:26 PM
davidwjacob
Yes i mean my truck, sorry, i just got this truck last week, i will go look at the door sticker later tonight when i get home from work.
thanks
Dave
