DTC's
Old May 26, 2014 | 11:35 PM
Cobra Highboy's Avatar
Cobra Highboy
DTC's
Hey all,
I have a 2006 F-350 6.0 I was driving yesterday and got the wrench light.
I have a bully dog PMT in it and am running stock (no tune).
I just bought the truck with the tuner, cold air intake, and 5" exhaust. I hooked up the tuner and checked DTC's. I got a P0487 (EGR Throttle Position control circuit) and a P1000 OBD 2 Monitor Testing incomplete.
I am wondering what these mean. I cant find a description on them other than what I have provided. Is this a major thing.
Also I was pulling my fifth wheel with atv trailer behind it (about 12,500 lbs) up a grade today. It was doing great but all of a sudden it beeped and said engine temp High, I looked at the temp gauge and watched it go from normal to hot in a split second. I pulled over and popped the hood (truck still running) the coolant was not boiling and the truck did not seem excessively hot. within about 10 seconds the temp gauge returned to normal and I continued my drive home without a problem. any ideas what could cause this? I am new to the 6.0. I have had a 96 F-350 with a 7.3 for 7 years now and never had anything like this happen to it. Thanks in advance for the help.
Old May 26, 2014 | 11:39 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
P1000 means nothing.
P0487: EGR actuator circuit check. open circuit, short to ground, and short to power.
Plug the EGR valve back in and the engine fan will begin operating as it should. Or the wiring harness is chafed, also causing the engine fan to operate incorrectly.
Josh
Old May 26, 2014 | 11:42 PM
Cobra Highboy
Awesome, thanks I will look into that tomorrow.
Old May 26, 2014 | 11:54 PM
dannyboy950's Avatar
dannyboy950
If the bully dog will read live data you need to look at your actual temps to determine of you have a real problem or if it was a glitch.
The dash gauge is not very good.[ read that junk]
Old May 28, 2014 | 05:27 PM
Cobra Highboy
Ok here is an update sort of. I restored the truck to stock and disconnected the programmer. By doing this I got a check engine light. I thjnk this truck has had an egr delete done thus throwing the CEL. If im thinking right the programmer will turn off the EGR sensor right? So my main concern right now is the wrench light with P0487 code. EGR TP circuit something. What do I need to look at there?
Old May 28, 2014 | 05:36 PM
Mike189677's Avatar
Mike189677
Yea the SCT will turn off the egr even with the canned tunes. You may just want to make sure the check engine light is for the egr and wether or you really have an egr delete or not. Also do you have an egr valve and if so is it plugged in and clean?
Old May 28, 2014 | 06:06 PM
Bullitt390's Avatar
Bullitt390
The OP has a Bullydog and not an SCT...
Josh
BGLeRoy
Apr 16, 2019 09:58 PM
Infotraker
Jan 12, 2019 12:50 PM
desertt5
Oct 21, 2014 01:28 PM
gdhillon
Jun 11, 2014 09:32 PM
vanderf
Aug 7, 2012 02:33 PM
