Sponsored by: Real Truck
2003 F250 cooling problem
Old Aug 5, 2012 | 08:12 PM
vanderf's Avatar
vanderf
When pulling a fifth wheel camper my truck seems to overheat when traveling at +55mph I have changed the thermostat water pump radiator fan clutch and flushed the system. Where else should I look Its a 6.0 motor never boiles over but the dash light still comes on after all the work. Any suggestions would be great
thanks vanderfp
Old Aug 7, 2012 | 11:15 AM
OSO86's Avatar
OSO86
I have read alot of issuses with the egr cooler and egr valve causing overheating and potential locking of the engine supposebly the the egr valve gets stuck and the egr cooler gets too hot causing the coolant to seep into the heads or evaporate from what i read. so check your coolant level always and clean your egr valve might help
Old Aug 7, 2012 | 11:22 AM
Budman1962's Avatar
Budman1962
Also replace the coolant cap. If it can't hold proper pressure it can cause overheating. Cheep item. It is a common problem.
$5 PART WILL SAVE YOUR POWERSTROKE FROM SELF DESTRUCTION - YouTube
Old Aug 7, 2012 | 11:48 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Do you have any kind of gauge setup to read the actual temps? Or are you just relying on the dash gauge?
Consider buying a ScanGauge:
Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive
If you can post up the actual temp reading, plus use the engine oil temp reading as a comparison, you'll be able to rule out a failed sensor/wiring harness issue, and maybe a whole set of other issues involving the oil system. Plus you can program is to read EGR valve position to see if that might be sticking.
Old Aug 7, 2012 | 02:33 PM
vanderf's Avatar
vanderf
Thanks I cleaned the EGR valve 6 months ago I can not hear the fan clutch enguage is there a way to test this circuit? Will check the other temps thank you all
Luke Langlois
Oct 8, 2017 01:50 PM
ontarioford
Jul 12, 2017 04:33 PM
ktownf350
Jul 12, 2014 12:41 AM
emmagator
May 25, 2013 09:54 AM
grahamdelooze
May 12, 2012 06:17 AM
