PEA Fuel Additive Mini Tutorial
Old May 25, 2014 | 02:30 PM
pawpaw's Avatar
pawpaw
Some input on fuel deposit control additive Poly Ether Amine (PEA) & why its a good idea for us to wait until just before oil change time to use an internal engine & fuel system deposit tidy upper. PEA and Amine-based Fuel System Additives | Technical and White Papers | Bob Is The Oil Guy
Old May 26, 2014 | 09:49 AM
finn's Avatar
finn
fuel additives are a waste of money. If they make you feel good, use them, but all they do is lighten your wallet.
Old May 26, 2014 | 02:01 PM
pawpaw's Avatar
pawpaw
The govt has mandated that All fuel we buy have an additive package minimum.
Some fuel ad packs are more effictive than others & some fuels have a higher concentration of ad pack, depending on who the marketer is & what label the fuel is being marketed under, like fuels marketed under the "Top Tie" label. If we use Chevron, Texaco, CalTex, Shell, they already have some PEA in their fuel ad pack. So adding additional after market PEA, like Techron Concentrate Plus, can raise the treat rate 10X above pump gas alone & can often tidy up fuel injectors, intake valves, piston crowns & heads in one treatment. So, if we choose wisely, we can often tidy up a deposit laden rough running engine with the proper recipe fuel additive.
Hundai & Kia recommend using Techron Concentrate Plus before an oil change, wonder what they know?????
Old May 28, 2014 | 12:39 PM
finn's Avatar
finn
Some fuel ad packs are more effictive than others & some fuels have a higher concentration of ad pack, depending on who the marketer is & what label the fuel is beiing marketed under, like fuels marketed under the "Top Tie" label. If we use Chevron, Texaco, CalTex, Shell, they already have some PEA in their fuel ad pack. So adding additional after market PEA, like Techron Concentrate Plus, can raise the treat rate 10X above pump gas alone & can often tidy up fuel injectors, intake valves, piston crowns & heads in one treatment. So, if we choose wisely, we can often tidy up a deposit laden rough running engine with the proper recipe fuel additive.
I was employed as an executive in research and development for a major engine manufacturer for over 35 years, and was responsible for fuels and lubes for a number of those years.
Additive manufacturers were constantly at our door peddling their latest mouse milk. Most oem's take sort of a non-aggression stance towards the mouse milk people, as it would tie up too many resources to qualify or disqualify them all. As soon as one goes away, another 5 pop up, sort of like dandelions on a lawn. Some oems even market some of these mouse milk items through their parts arms as a profit center. The stuff rarely does any good, but as long as it doesn't hurt anything and they can fleece the consumer, why not get in on the action and pocket some money.
Stick with quality fuels and lubes. The oem engine manufacturers work closely with API and other industry groups to establish quality standards.
The aftermarket marketers of these additives are largely *****s. All they care about is their pocketbooks. Their disciples are passionate, however, and truly believe in "overhaul in a can" or whatever the latest marketing hype is for th mouse milk of the day.
It is sort of like late night food supplement pitches on tv, or maybe the latest incarnation of the vegamatic..
Old May 28, 2014 | 01:48 PM
pawpaw's Avatar
pawpaw
^+1 on using a quality lube & fuel & I'd add quality filters too!!!!
4bigred
Apr 22, 2022 06:00 AM
Pitcrw6
Oct 24, 2012 10:59 AM
bismic
Sep 30, 2007 01:27 PM
PSDLOVER
163
Jun 11, 2006 11:13 PM
enginethatdid
1997 - 2003 F150
Jun 25, 2003 05:16 PM
