1978 - 1996 Big Bronco
No Start...need help
Old Jul 7, 2003 | 11:21 AM
maulsmasher's Avatar
maulsmasher
I have a 96 EFI 3.2l Bronco.
I left for work this morning and it started fine. I stopped to get gas and when I went to start it back up it wouldn't start. It sound like the started is turning the engine, but it just won't start. I checked the feul cutoff switch and it was still engaged...I guess my question from here on is what are the simple things to check first before looking at major things? What is a procedure to check it? Any info will be helpful.
Another question...say it is the feul pump what is an estimated cost on having it replaced?
Thanks
Old Jul 7, 2003 | 11:48 AM
steve83's Avatar
steve83
The Bronco NEVER had a 3.2L engine. That would barely get it rolling.
'96 Broncos have an OBD-II computer, so find a local parts store that pulls codes free and see what errors the computer has noticed.
Old Jul 7, 2003 | 11:49 AM
maulsmasher
.302
Old Jul 7, 2003 | 11:51 AM
steve83's Avatar
steve83
If you can't get it hooked up to a scantool, buy a Haynes manual and read the Troubleshooting chapter.
Old Jul 7, 2003 | 11:52 AM
maulsmasher
sorry it was a typo it is a 5.0l. Anyway as far as pulling the codes is there an alt. since I can't get my Bronco anywhere since it won't start.
Old Jul 7, 2003 | 11:53 AM
maulsmasher
I actually am doing that currently. Only problem is could it be as simple as a bad fuse or relay?
steve83's Avatar
steve83
No. OBD-II codes can't be pulled without a scantool. The Haynes manual will show you how to check the fuses & everything else. Just read the Troubleshooting section, the Fuel & Exhaust chapter, and examine the wiring diagrams in the back. Your '96 is slightly different from the '92 wiring shown, but it's close.
Old Jul 7, 2003 | 11:55 AM
maulsmasher
Is this scantool something that could be rented or bought?
Old Jul 7, 2003 | 11:56 AM
steve83's Avatar
steve83
A cheap one costs ~$150 and won't reprogram the computer. You might be able to borrow one from a parts store by leaving a (full) deposit.
Old Jul 7, 2003 | 11:58 AM
maulsmasher
I'll look into that. Thanks for your knowledge and help.
Old Jul 7, 2003 | 12:30 PM
AlM's Avatar
AlM
yo,
just for the heck of it...I did son #2 a favor by getting his car inspected, then washed it and filled gas tank at a chitNoGo station...got home and then..cranking, but no runny....tuens out they had diesel fuel in their tanks...
just letting you know about the simple, but dumb check..
Also, how's da battery and terminals/cables/? Is it turning over as well as normally?
Old Jul 7, 2003 | 01:25 PM
maulsmasher
Damn that is something I didn't think of. How did you solve that problem?
The battery terminals and cables are all fine.
Old Jul 7, 2003 | 01:50 PM
AlM's Avatar
AlM
yo,
We had a freakin' adventure trying to figure out what happened. Eventually, we called the station and they admitted that they had a full tank of diesel in their reg octane gas tank(s).
some said that it couldn't reach the engibe because the fuel filter would clog; but the diesel did reach the plugs, etc.
One way to ck is to look at a plug or two and see if it is fouled; another way is to take a sample of the gas to get it analyzed at a dealership (where the car was towed to after we tried to read the codes).
Call the station for the heck of it and ask them if they've had any complaints.
wolfrace
27
Jun 17, 2010 03:08 PM
bro460
Modular V10 (6.8l)
Aug 5, 2009 10:48 AM
cornfeed
Electrical Systems/Wiring
Apr 11, 2006 04:00 PM
mtttricker
Sep 11, 2005 06:04 PM
retrogod1
38
Aug 26, 2005 09:22 AM
