Hydroboost and Brakes
For the record, I wasn't unhappy with the braking performance of the F350 stuff. I am just mad that it didn't last.
I can't prove or disprove it, but I can offer the personal anecdote that the stock brakes on my Bronco were unsafe and, after a series of gradual changes, hydroboost fixed the issue.
At first, everything but the hard lines and proportioning valve were replaced with stock units with no difference; then the lines and valve were replaced with no difference.
After that came the full one ton swap and "T-bird," calipers and one ton wheel cylindiers with a marginal improvement but not the point that I felt safe if I needed to panic stop. Then the gutted proportioning valve and rear disks were installed with no improvement. I even took the master cylinder and booster back and exchanged it for another, thinking at this point that I'd obviously gotten something that was no good.
At the time, about 11 years ago, I had used the Cadillac calipers and got frustrated enough trying to bleed them that I took them to a shop to bleed them.
Maybe that master cylinder wasn't up to snuff for the rear disks, but it didnt work well with drums either.
Thinking back to driving that vehicle back then, there's no way I'd drive it on the freeway today if it were still acting the same and I sure as HELL wouldn't have any of my friends in it.
But then, after putting hydroboost in (as well as ditching the Cadillac calipers in the back in favor of something that actually works), the Bronco stops as well as any modern truck.
Maybe it was all chance that I'd just gotten bad part after bad part 'till the most recent swap, but the hydroboost has been running strong since 2010 or so and hasn't let me down in any way.
None of this is intended to change your mind, as I dont think anyone here will do that...but at least one vehicle out there has had a significant positive difference from it. I dont have a way to show to you on paper that it's more than a placebo, though.
If your stock system is working safely, I think that you are probably pretty damn fortunate.
There are probably some stock lines that will work with whichever pump you use, but I built my own out of PTFE hose and swapped everything over to steel AN fittings. The Saginaw pumps have at least two outlets they can come with; older ones, maybe mid 80's back seem to all be standard reverse flare and newer ones, up through modern production have all been metric with an O-ring, from what I've seen, so plan your lines or fittings accordingly.
Besides the hoses, the only thing that had to be custom on mine was a bracket to mount the booster to the firewall. The actuator rod fit onto the shoulder bolt and bushing that came stock with the truck.
If I had it to do over again, I'd use generic AN adapters and hose from Aircraft Spruce or someplace like that instead of ones from Jegs or Summit or wherever I got mine from. The regular steel braided aircraft Teflon (also sometimes generically labeled "PTFE," hose) will run just about any fluid and is rated to 3K PSI working pressure. I've routinely tested it to 5K PSI with no failure.
If you convert to AN fittings, be sure to mark your steering gear box's in and out ports. Hooking them up backwards is unpleasant, I've heard. Also, dont use aluminum fittings. Not only are they not rated to the strength of steel fittings, but the steel in your booster and steering gear box doesn't play well with the aluminum fittings, even with the anodized coating and having a corroded fitting rupture while going around a corner isn't what you want; it makes a mess.
+1
...wonka is now flippin burgers: with the oompaloompas and asking if ya'd like fries with that.
...he was a punk.
</O
