front axle
Old May 23, 2014 | 08:08 PM
newguy399's Avatar
newguy399
front axle
Hey guys about to assemble my front axle after painting,was wondering which way the axle goes with the serial number facing front or back. Also which way does the kingpin locking bolt go in from the front or the back, thanks again
Old May 23, 2014 | 08:15 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Can't help with the serial number, but the locking bolts go in from the front.
Old May 23, 2014 | 09:16 PM
AXracer's Avatar
AXracer
I don't have an answer because I don't know what you are working on or where you are, both can be helpful when answering questions. Go to the blue band just above this forum, at the far left click on User CP add your location then add a signature that contains the year and model truck you are working on.
Old May 23, 2014 | 09:58 PM
newguy399's Avatar
newguy399
Sorry ax thought it was already setup will do when I get a chance to get to a real computer but its a 1956 f250 with a f100 front end and I'm in Tinley park il
Old May 24, 2014 | 06:14 AM
raytasch's Avatar
raytasch
Believe Nothing
The straight axle is installed with the king pin tipped toward the rear a couple degrees. The angle is called "caster". Seeing the caster angle can be difficult but doable. Place a dowel or other snug fitting tool in the king pin hole and the angle will be more easily seen. There may be witness marks on the back side of the axle where the turn limiter screws have hit.
Old May 24, 2014 | 12:16 PM
newguy399's Avatar
newguy399
Thanks for the info ray.
Old May 24, 2014 | 11:08 PM
AXracer's Avatar
AXracer
Before you bolt the axle in place, add a set of caster shims between the axle and the spring to increase the caster (tip the top of the axle back more) if using stock springs or two sets (you'll need spring center bolts with longer heads if using 2 sets) if you have removed leafs or are using lowering springs to increase the caster for highway use. The stock setup is caster challenged to make low speed steering easier back when parallel parking was the norm. Be sure to put two large C clamps on the spring one each side of the centerbolt if changing them, the spring packs a lot of tension, and can fly apart with substantial force if the bolt is suddenly released.
vincel1965
Dec 13, 2012 04:13 PM
thunderguns71
Dec 13, 2004 07:51 AM
he race me
Apr 25, 2004 01:25 AM
Rednecknutcase
Mar 3, 2004 05:51 AM
