Ex overheats
Old May 24, 2014 | 07:40 AM
Lost Yankee's Avatar
Lost Yankee
Atom, I havent taken it off, but I will pay attention when i start to pull her apart and replace parts so I dont screw it up.
Old May 24, 2014 | 08:39 AM
ExxWhy's Avatar
ExxWhy
Did you have the same problem prior to last week when you changed the tank?
Old May 24, 2014 | 08:43 AM
Lost Yankee
ExxWhy, I had to change the tank because it started to leak, I did a 3 day clean with some prestone clean and flush, thats when the tank started to develope leaks.
Old May 24, 2014 | 11:08 AM
ExxWhy's Avatar
ExxWhy
Just to be clear, prior to the flush and subsequent tank change, it did not overheat?
If so, sounds like you have some crud that was dislodged in the flush and is now in the radiator. More thorough flushing sounds like the next step with both hoses off and a garden hose pushing a lot of water both ways through the radiator. .
Old May 24, 2014 | 11:25 AM
Lost Yankee
Yes Sir, prior to all that I didnt have a problem, I am going to try one more bottle of clean and flush after work and pull the lower hose of the radiator and rig a garden hose to the expanstion tank hose and see what happens, other wise I will have to order parts from ford and they will not be here till wed due to the holiday.
Old May 24, 2014 | 01:28 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by ExxWhy
...sounds like you have some crud that was dislodged in the flush and is now in the radiator.
That was my thought, that's why I suggested the rad as the source of the problem.
The rad is still flowing, just not the volume needed at freeway speed/engine load in order to cool properly.
A radiator shop can check the flow for you.
Stewart
Old May 24, 2014 | 05:42 PM
Lost Yankee
Well, its starting to come together as to the problem, I noticed the cap was cocked after she overheated and thought I put the cap on cocked, but it is the threads on the tank, they don't hold the cap tight, I put some Teflon tape on the threads and it seems to work, no more parts store parts for me, thanks for the help guys.
Old May 24, 2014 | 06:20 PM
EXv10's Avatar
EXv10
It's important to have those caps working right and you can check them an O'reillys at the counter. If those threads are bad I would get another overflow tank.
Old May 24, 2014 | 07:14 PM
Lost Yankee
ExV10 I have to wait till tues to get a ford oem tank due to the holiday. I have had 2 caps on the same tank, the one it came with and a ford oem cap, only thing different is several layers of 3/4 " Teflon tape on the tank threads and I am using the new ford cap, so come tues and $120 later Ill have a oem tank , I just put 20 miles on the highway with no temp rise and Teflon tape so it seems to be the threads on the tank.
Old May 24, 2014 | 08:21 PM
EXv10's Avatar
EXv10
Wow, can you get one from a wrecking yard? I bought a new cap that just spun on my tank this year and the next one was defective so I went to Oreilly's and borrowed their tank and cap testing kit for free, then their new thermo was defective which I discovered by heating it in water on the stove and replaced that with a Motorcraft one and finally got my overheating and failsafe problem over with. Those things are cheap so it pays to get OEM ones but I can't believe they want so much for a tank. If you have an Oreilly's there you can test that whole system with their free loaner tools.
tuxedobuttonquail
53
Jan 9, 2017 08:04 PM
cdow19
Jan 31, 2011 03:06 PM
Montana2mass
Oct 21, 2008 10:40 AM
460429_freak
Dec 29, 2005 03:54 AM
Tedster9
Mar 5, 2004 07:54 PM
