ding ding ding ding when driver's door is open
Old May 22, 2014 | 10:59 AM
kind153's Avatar
kind153
2003 Navigator..bought used.
It dings when the door is open, as if light is on...or key is in?
It had a bad lock cylinder that prevented the key to come out..so I replaced it.
Is there anyway to reliably tell what's causing this? or is this.........normal?
Thanks!
Old May 22, 2014 | 11:00 AM
alloro's Avatar
alloro
I'd go with the key (is inserted) contacts in the ignition switch being damaged.
Old May 22, 2014 | 11:03 AM
kind153's Avatar
kind153
Thank you. Any insights on what to look for? I don't mind taking it apart again to get rid of this!
Old May 22, 2014 | 12:12 PM
alloro's Avatar
alloro
You should remove the lower steering column shroud as well as the ignition lock. This way you can do a good inspection to see what is wrong. I had this very issue when I bought my first expedition years and years ago. I don't remember exactly what I did, but it was definitely something to do with the key contacts.
Old May 22, 2014 | 01:45 PM
projectSHO89's Avatar
projectSHO89
Remove the bottom shroud, look for a purple/black wire. Clip the wire to eliminate the key-in-ignition buzzer or else fix the little contacts where the wire gets attached.
Old May 22, 2014 | 02:01 PM
kind153's Avatar
kind153
Amazing. Thank you! I'll try and report back!
Old May 25, 2014 | 06:19 PM
kind153's Avatar
kind153
Thank you, projectSHO89!
Instead of clipping, I simply pulled the purple/black wire and put it aside. Here is the picture of the cable and the location of the connector.
milkstake
Jun 14, 2017 07:04 AM
jlgriff76
Oct 20, 2013 09:03 AM
Rick2324
13
Nov 23, 2005 10:01 AM
Michael Sizemore
May 5, 2004 06:46 AM
jeremybillie
1983 - 2012 Ranger & B-Series
Jan 1, 2004 02:12 PM
