Fixing AC Black Death?
Old May 22, 2014 | 09:19 AM
heartnurse73's Avatar
heartnurse73
What have you done to clean the lines? I have unfortunately came across this problem now. Pulled the office tube filter and blacked out with a Vaseline like grease. No flow what so ever.
Please help. What components do I have to replace as well? Obviously the compressor, but what else have you replaced with luck in making it work.
Thanks,
Jay
Old May 22, 2014 | 05:41 PM
Restlesswildman's Avatar
Restlesswildman
go to your local jobber parts store, not your local box store and ask for a A/C flush kit.
Flushing the A/C system isn't to bad of a job, but requires that you do a thorough job and use the right chemicals.
Usually the black death goo is due to a compressor that died a bad death. You will need to pull the lines in a few places such as the compressor, condenser an evaporator(at least that is how I do a A/C flush). You should replace the accumulator or expansion valve depending on the system and orifice tube.
Make sure that you clean everything in the system 100%!
Old May 22, 2014 | 06:08 PM
je5's Avatar
je5
Replace the system.
Old May 23, 2014 | 07:02 AM
mahdeys's Avatar
mahdeys
if the cooling lines are thin fins, these cannot be properly flushed and need replaced. Flush kits are meant for older design with the oval/circular cooling passages. If this was my truck i'd be pulling all lines to flush and replacing cores, condesnor, drier, compressor, o-tube and rear expansion valve.
Old May 23, 2014 | 07:07 AM
heartnurse73
Yep, got all the stuff on order! The only thing not ordered was lines. Gonna flush them, then reassemble the thing. Good weekend project.
supertramp
31
Jun 14, 2016 03:28 PM
john jamieson
1983 - 2012 Ranger & B-Series
Aug 25, 2015 06:02 AM
snorindad
Jun 24, 2015 01:26 PM
78bigunns
Feb 10, 2013 11:57 PM
acaptain30
Jul 12, 2007 09:09 PM
