Going to the local pick n pull this weekend for their 50% off sale, looking for ideas for some things to look for for my 95 f150....any suggestions for upgrades etc?
Stuff you can get for junkyard upgrades, depends what your into. Here's what I'd get if I had your truck
Cab lights
Toolbox
Ranch hand rear bumper
Grille guard
Halo headlights or led tail lights (if your lucky enough to find some)
Split front bench if you don't already have one
Leather wrapped steering wheel
Any spare parts that you think you need
I would look for crew cabs and steal the power window/power mirror bezels from the drivers door only,and rear door panels and post them for sale on the forums and craigslist. These parts are hard to find, and they are cheap in a junk yard and will PAY for anything else you bought that day for your truck.
Didn't see any on the list, but will have my eye out regardless...I have a crew cab centurion conversion so spare parts would come in handy...
Are the 1997 f250s solid axles in the front? Thoughts on axles from a 97 f250 into my f150? Nothing wrong with mine currently...
You could always pull the inner stub shaft from an F250 with a D50. The inner universal joint is a size bigger which allows for more droop before binding occurs and makes the weak point the stub shafts and joints. Not much else will swap over other from the 3/4 tons other then the third member, but I wouldn't bother unless your wanting to change gear ratios.
