On the way to work the other day The CEL came on. No change in the way the truck runs. I stopped by the local auto parts and got them to read the code for me. P06EB, did internet search and got that it was associated with DEF Fault and forced engine idle which I don't have. I"ll be taking to dealer to get checked out.
Let us know when you have an update from the dealership, 4df150. How many miles do you have on your truck?
1st update - Went and filled up the truck with fuel today. Was going to take to dealer to check the code on Monday. While I was driving I heard a "ding", I looked at the display and the CEL was gone...WTF...Next time I'm by the dealership I'll stop in and have them check the code. All is good in the neighborhood.
Update on "P06EB" code.....
I've just been resetting the CEL when I get this code because it doesn't come back for 4 to 6 weeks.
I got the CEL going to work last month at 1 am. Truck running good. Reset CEL. Drove on to work without any more CELs. Parked truck for 2 weeks.
On way home from work got CEL again an was able to get to dealer.
This is what they found.
"CEL was on in truck and when I pulled codes using IDS I only got one code "P06EB". Found TSB-14-0203 for this code and following this code I had to replace one EGT sensor 14. Replaced sensor road tested no more CEL. truck runs good."
So far so good but time will tell.
Can anyone post what TSB 14-203 is??? Google search did no go....
