Shift lever adjustment?
Old May 21, 2014 | 06:58 PM
emmagator's Avatar
emmagator
Any secret to adjusting the shift lever? Mine has alot of play in it. Under dash somewhere? Thanks
Old May 21, 2014 | 08:24 PM
cheezit's Avatar
cheezit
Check for loose bolts at the bottom of th column.
Old May 21, 2014 | 08:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are two #30 Torx bolts that hold the shift cable bracket to the shift tube. They loosen and cause a sloppy shift handle.
Old May 22, 2014 | 02:22 AM
BigAlsPSD's Avatar
BigAlsPSD
Like the others have said, for a sloppy shifter check the torx bolts at the bottom of the column.
The if you need to adjust the indicator, there is a thumbwheel to line it up as you need it. Behind the fuse panel on the bottom of the column.
Old May 22, 2014 | 08:02 AM
emmagator's Avatar
emmagator
Great, thanks guys
Old Jun 23, 2014 | 04:54 PM
SteveW84RC's Avatar
SteveW84RC
In an effort to add something to this thread.............
A mechanic friend went to Roosevelt Lake in AZ this weekend and spotted a friend with a broke down problem with his 2002 F250. Shifter would not select any gears, or Park. He was dead on the road.
The problem was that the bolts shown above had come loose and fallen out and the shifter was completely unusable. Found the bolts on the floor and fixed the problem. Lucky for him he had a #30 Torx in his tool box (Note to self, put #30 Torx in truck emergency tool box).
My mechanic friend immediately checked his 2002 F250 after fixing the other truck and guess what? All of the bolts on his gear selector bracket were loose!
When he came to work in his shop, Lloyd's Transmission and Driveline, Tucson, AZ, he checked the 2003 F350 in the shop, and guess what?
He called me and told me to get my 2000 F250 down to his shop ASAP. I drove down there and guess what?
Here is a video:
Amazing! Four out of four were loose! Not good.
Check yours today !
Steve in Tucson
Old Jul 18, 2014 | 02:37 PM
Marobel's Avatar
Marobel
This worked perfectly. My shift column was not as bad as the video described but it was close!! The T30 bolts were 2-3 turns backed out and the shifter lever was loose as hell. I have the driver in my toolbox and have never used it. Thanks Steve for the description, the post and the video. That was the trick for my truck. Now to fix the turn indicator lever, which is similarly loose and is effecting my wipers/washer.
Thomas Hutchins
1997 - 2003 F150
Aug 25, 2014 09:49 PM
michaelskerrett
Jun 25, 2014 11:18 AM
iowa 7.3
Sep 6, 2013 01:18 PM
66_in_ky
May 6, 2010 09:25 PM
ajordan193
Mar 16, 2007 07:58 PM
