Rear End Leak
Old May 21, 2014 | 02:49 PM
1965fairlane's Avatar
1965fairlane
Rear End Leak
I spent a couple of hours cleaning the years of gunk off of the rear end a couple of days ago and looked under the truck last night to see this...
It looks like it is leaking out of the weld and the top rear of the diff...
Here is the other side...
Would a guy just weld that spot to keep it from leaking further? Have you seen a leak like this before?
I have read on this site that the fluid level in the diff is full when it starts to leak out of the access plug. I am going to re-torque the bolts on the other side as well.
Old May 21, 2014 | 03:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, the full level is at the bottom of the fill hole. The front pinion support uses an o-ring for a seal, it also has adjustment shims so if you take the pinion out to replace the o-ring, be sure to put the same shims back in.
As for the leaking weld. You could weld it or maybe try something like JB Weld or something similar.
Old May 21, 2014 | 03:57 PM
1965fairlane
I assume you are talking about the pinion retainer o-ring in this diagram?
If I drop the driveshaft, etc and replace the pinion support O ring, I assume that will also cause a majority of the fluid in the diff to leak out? Maybe get me closer to a complete fluid change in the rear end?
I haven't ever torn one apart before.
Old May 21, 2014 | 06:05 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes and yes.
Don't be afraid of the Ford 9". It's probably one of the easiest rear ends to work on.
Old May 21, 2014 | 07:36 PM
redroad's Avatar
redroad
Is the vent working properly?
Old May 21, 2014 | 08:59 PM
Blue and White's Avatar
Blue and White
First thing to check! If it is holding pressure inside the rear it will leak. Remove the vent from the axle tube and check that the hole is clear and cap loose and clean. Some wire and brakeclean or parts washer will fix it if needed. Repop vents are available also.
If it still leaks, I would fix the weld with JB weld. Clean thoroughly... brake clean and wire wheel and more brakeclean then apply JB weld to the area. This repair should last as long as the rest of the rear.
Old May 21, 2014 | 09:07 PM
GLR's Avatar
GLR
I almost think Ford had a TSB on leaky welds when I worked at a dealership. If CRS isn't involved , the guys in the body shop re-welded quite a few.
Old May 21, 2014 | 09:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Good point that I overlooked! The axle vent looks like it's big but once you take it off, you'll see the actual vent hole is pretty small and it will plug up easily.
The vent is also the hold down for the rear brake hose to axle housing. In the picture the vent is the piece that has the vent line with the green hose clamp on it.
Old May 22, 2014 | 07:49 AM
1965fairlane
Thanks for the responses. I am going to check the vent and try the JB Weld for sure. Once I have those squared away and the fluid level topped off, I will try to retorque the bolts on the other side. If I still have a leak, I will tackle replacing that o-ring.
I'll keep you posted with what I find out.
Thanks again!
Old May 22, 2014 | 11:23 PM
1965fairlane
Excellent call on the vent hose It was plugged with spiderweb/eggs...
Cleaned out the line and the connection on the axle itself. Mixed up a little JB weld to fix the leak and added about 1/5th of a new jug 80w90 gear oil.
Now I am on the hunt to figure out what the tag on the rear end is telling me. I am pretty sure I saw a decoder in the LMC parts book on-line.
Old May 22, 2014 | 11:51 PM
1965fairlane
The tag reads...
WDM CJ 9EA
2 75 9 356A
I found the following on the Fordification Site...
WDM-CJ = Ford F100, F150 Pickup '79
2 75 = 2.75 Gear Ratio
9 = 9 inch ring gear
Non-locker
9EA = 1979 May 1st
Not sure what the 356A means...
Old May 23, 2014 | 05:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The tag reads: WDM CJ 9EA / 2 75 9 356A
I found the following on the Fordification Site: WDM-CJ = Ford F100, F150 Pickup '79 / 2 75 = 2.75 Gear Ratio / 9 = 9 inch ring gear Non locker.
9EA = 1979 May 1st / Not sure what the 356A means...
WDM-CJ does not decode to F100 or F150 or pickup or ring gear size. Some 9's also came with 8 3/4" ring gears. It also doesn't decode to Non locker.
2 75 decodes to 2.75-1 non locking (no Limited Slip). 2L75 decodes to Traction-Lok (Limited Slip).
9EA = Assembled the first week (A) of May (E), 1979 (9).
356 = Assembly Plant code / A = initial design, B would be 2nd design, C the 3rd and etc.
Old May 23, 2014 | 06:53 AM
redroad's Avatar
redroad
That's great news BTW really sweet truck and set up .. Something you might think about when or if you are going to rebuild the C6 trans .. A built C4 would give you back 30-35 Hp but a drive shaft change would be needed also I believe .. It all depends what your using the truck for I guess
A good thread on auto trannys
Old May 23, 2014 | 07:34 AM
1965fairlane
Thanks for clearing up the 356A NumberDummy! I got the WDM-CJ off of the chart from the Fordification website. See the screenshot below....
I assumed that the NL on that grid meant non-locker?
Old May 23, 2014 | 07:46 AM
NumberDummy
Neither of these charts are FoMoCo related! 2nd chart, column right: These codes weren't used until the 1980's.
These charts were taken from the awful Red Book, a POS originally written/published by and foisted on mankind in the early 1970's by two clueless clucks who were members of the Fabulous 50's Ford Club.
It's been updated several times since, the two clucks have since sold the publishing rights to another clueless cluck. Most of the info is mis-leading or WRONG!
FoMoCo: The WDM-CJ portion of the rear AXLE ID tag only decodes to this:
99ExpyProblems
Sep 10, 2013 10:36 AM
amdriven2liv
Sep 5, 2013 09:16 AM
kevin.ford-trucks
Sep 8, 2011 07:31 AM
Champ198
6.4L Power Stroke Diesel
Jul 23, 2010 08:18 AM
dalton
1997 - 2003 F150
Sep 8, 2003 06:07 PM
