explore
Old May 20, 2014 | 07:42 PM
sam88's Avatar
sam88
explore
hi everyone....i have ford explorer 2008 xlt...and i had an issue which is first RSC service now ( roll stability control) and ckeck out by computer and gave me those codes :
p1891
p1867
p1825
c1233
c1155
the machanic said the main problem is pms(the computer of the car) and its expensive .....should i replace it or there is/are other problem regardless pcm..the car doesnt response when the gear is on "D" when i exceed 40km/h
thank you
Old May 21, 2014 | 07:01 AM
shorod's Avatar
shorod
Based on the list of codes, I would not be condemning the PCM or the RSC systems. Your current codes seem to pertain to two systems, the transfer case and the LF wheel speed sensor for the ABS.
-Rod
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">P1825 </td> <td align="left" valign="top">4-Wheel Drive Clutch Relay Open Circuit </td></tr></tbody></table>
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">C1233 </td> <td align="left" valign="top">Speed Wheel LF Input Signal Missing </td></tr></tbody></table>
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">C1155 </td> <td align="left" valign="top">Speed Wheel Sensor LF Input Circuit Failure </td></tr></tbody></table>
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">P1891 </td> <td align="left" valign="top">Transfer Case Contact Plate Ground Return Open Circuit </td></tr></tbody></table> <table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">
</td> <td align="left" valign="top"><table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">P1867 </td> <td align="left" valign="top">Transfer Case Contact Plate General Circuit Failure
</td></tr></tbody></table> </td></tr></tbody></table>
uglypitbull
Feb 10, 2019 03:35 PM
Mike0929
1997 - 2003 F150
Dec 19, 2016 07:53 PM
azshane1
Mar 16, 2008 10:43 PM
88-150
Aerostar
Feb 11, 2007 12:10 AM
Gil_B
Oct 19, 2001 04:34 PM
