Trailer lights
Old May 21, 2014 | 08:09 PM
yfz 450's Avatar
yfz 450
Will do thank you
Old May 24, 2014 | 08:39 AM
retiredsparky's Avatar
retiredsparky
Chris (f350-6) that is good information on the location of the fuse block in 2002 and later. It can be very time consuming to find the source of electrical problems.
Good luck to yfz 450. Please let us know if you find out where the problem lies. I do not remember if you unplugged the last short harness that goes to the trailer receptacle at the bumper to test. It is only a few feet long and can often be the cause of loss of power. The connector between the two harnesses can get corroded or the wiring can be exposed to damage. Larry
Old May 27, 2014 | 06:13 PM
beancounter52's Avatar
beancounter52
I'm just setting up a new utility trailer. I got turn signals and brake lights, but no running lights. Truck is a 2011 F350. Got any ideas? I have checked the trailer and it is wired correctly. Truck lights work corrrectly. Only cant get running lights on the trailer. Is it possible that the BROWN wire from the truck has a blown fuse?
Melanie Ross Thaxton
2009 - 2014 F150
19
Sep 25, 2023 12:29 PM
V10man
Mar 16, 2014 06:07 PM
lilpro
All Things Towing
Jul 6, 2009 01:35 AM
jake00
Jul 27, 2007 09:15 AM
jake00
Jun 11, 2006 11:25 PM
