Boxes
Old May 20, 2014 | 11:53 AM
dirtyb's Avatar
dirtyb
Boxes
Are the "fleet side" boxes off of a 63 f100 the same as the 57-60 trucks? Some pictures I see, the box looks completely different and some look the same. I have a 59 stepside and want to switch to the "fleet side.
Old May 20, 2014 | 11:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a stepside and want to switch to the "fleet side."
Welcome to FTE
Styleside = Ford / Fleetside = Chevrolet/GMC / Flareside = Ford / Stepside = Chevrolet/GMC.
Pics from 1957/63 Ford Truck Parts Catalog.
Pic at left: 1961/63 F100/250 2WD Uni aka unit-body aka integral body: Styleside beds welded to the cab.
Pic at right (lower): 1957/60 Styleside beds installed on the following 1961/66's. Called the "wrong" beds, because the bed lines do not match the cab lines.
1961/65 F100/250 4WD - 1961/66 F350 (9' Express) - 1962/63 F100/250 2WD - 1966 F250 4WD
Old May 20, 2014 | 12:39 PM
dirtyb's Avatar
dirtyb
Ok thanks for the info and the welcome. next question is what is a box in decent shape worth? I found a 63 with a "wrong" box on CL. in the pictures the box looks good except for the back under the tail lights. The rest of the truck looks trashed almost like the box was off the truck for awhile???
Old May 20, 2014 | 03:26 PM
NumberDummy
Price varies, depending on where the bed is located. Worth much more if in the "Rust Belt." Far less if located where salt isn't used on the roads (Desert Southwest and etc).
Supposedly, the bed extensions (panels where tail lights are located) have been reproduced, but by whom, I cannot recall.
Old May 20, 2014 | 05:14 PM
Damifiknow's Avatar
Damifiknow
I've seen "wrong bed" trucks. Look like a hodgepodge of parts mixed together. Just my opinion. Logic says these would be worth more money cause they should be rare.
This looks like a decent bed. Kinda pricy.
http://chicago.craigslist.org/chc/pts/4437423869.html
Old May 20, 2014 | 10:06 PM
finn's Avatar
finn
The gentleman I bought my '59 from also had a 60 which had a bed from a '63. Per my conversation with him, the mounting holes on the 62-66 bed are in a different location, otherwise the beds are the same
I'm not sure where this "wrong bed" stuff is from. Simply put, Ford was pushing the new integrated bed in the 61-63 model years, with a flareside bed as an option for those that didn't want the integrated bed. When the integrated bed didn't meet the customer expectations for durability in severe applications, Ford, in 1962, reached into the parts bin and pulled the (already tooled) '57-60 bed out as a functional alternative until the so called "correct" bed was released in 1964 and the integrated bed pickup option was cancelled.
The "wrong bed" soldiered on in low volume 4X4 applications (different cab / axle dimension) for a few more years.
Economics, son. Simple economics.
They were quite common, and never called "wrong" when I was a kid in the 60's.
Old May 21, 2014 | 05:45 AM
NumberDummy
When I first joined FTE, I read posts where others were calling the 1957/60 beds...when installed on 1961/66's, the "wrong" bed.
"Wrong" makes sense, since the bed lines don't match the cab lines. 1961/66 F350: The only Styleside bed available: "Wrong" 9' Express.
1964/66 F100/250 2WD & 1966 F100 4WD used different Styleside beds, that some people call the "correct" beds. But, "correct" is a misnomer, since these beds weren't available 1961/63.
Old May 21, 2014 | 08:24 AM
finn's Avatar
finn
Bill: Am I correct in believing that the only "wrong bed" 61 Fords were the 4X4's? The "wrong" bed wasn't reintroduced on the 4X2's until 1962.
I think I read that somewhere and my memory from when I was 10 and 11 years old isn't perfect!
corkinaz
Mar 5, 2019 10:19 AM
ecoop19902002
Jun 1, 2017 11:53 AM
lefty rodan
Oct 11, 2009 03:52 PM
Rodney F-100
Dec 3, 2004 05:34 AM
wolverineflight31
Sep 22, 2001 11:15 PM
