60 truck 66 bed?
Rodney,
51dueller is right on. If you are still confused...................
Ford produced the uni-body (integral bed & cab) from 1961 thru 1963 for 2wd trucks only.
"Seperate cab & bed" version 2wd trucks were also available for these years (1961-63) to those who did not want a uni-body. The 1957-60 style bed was used on these trucks, and also 4wd trucks.
Here's a list of what the 1957-60 style 8' beds were available on.....
1957-60 F-100 & F-250 (of course)
1961-63 non-unibody trucks & 4x4's
1964 F-100 & F-250 4x4's
1965 F-100 & F-250 4x4's
1966 F-100 4x4's (with 115" wb only), F-250 4x4's
Since your truck is a '60, it was only available in "seperate cab and bed" version.
It is possible that your bed was replaced by the seller with a bed from 1966 4x4, or any of the other trucks listed above. It would indeed match your truck perfectly because both trucks used the 1957-60 style bed.
I don't believe there is a way to identify the "exact" year of the 1957-60 style bed by looking at it. I don't think they were stamped with any numbers.
I hope this helps.
I hope this helps.
