T5 Conversion
Old May 20, 2014 | 12:54 AM
schano58's Avatar
schano58
T5 Conversion
I've become a FTE member to learn from those with experience. I inherited a 1972 Sport Custom from my father and plan on keeping it in the family. I recently replaced the three on the tree with a T5. Not a bad job. Everything fit right into place. The problem I'm having is finding a clutch cable to convert from the original rod set up. I bought a conversion kit for a 70's model Cougar, but it broke in less than 3 months. The kit was pricey and came with hardware I didn't need. I just need the cable. Any suggestions?
Old May 20, 2014 | 10:27 AM
Torklift Sheryl's Avatar
Torklift Sheryl
SPONSOR
Hello and welcome to the forum! This is the perfect place to find a ton of valuable information. Enjoy!
Torklift Jen
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old May 20, 2014 | 10:43 AM
85e150's Avatar
85e150
Welcome to FTE.
Why did it break? Interference, wrong angle, poor quality, poor fittings?
Cable is available from a variety of sources such as hardware stores and aircraft suppliers:
Aircraft Cable Assemblies - RiggingWarehouse.com
Aircraft stuff would be my choice. Them airplane fellers are real particular about cable, and the FAA carries a big stick if your parts fail. You may have to adapt or make your own fittings etc, but all the stuff is available.
Back to failure analysis--no cable will last if there is interference or if the angles are wrong, so correct any problems and protect the cable when you do this repair.
You've probably been through all this, but this outfit sells the kits and there may be serving suggestions here:
How To Install A Modern Drivelines Cable Clutch Linkage - Mustang Monthly Magazine - View All Page
Classic Muscle car T5 swaps, Tremec TKO Conversions, Mustang, Cougar, Falcon, GM and Mopar swaps
Old May 20, 2014 | 11:03 PM
ATV PRO #11's Avatar
ATV PRO #11
Welcome aboard!!!!
Old May 21, 2014 | 01:57 AM
schano58's Avatar
schano58
Thanks a bunch for the cable info. I'll figure it out. I was kinda hopin' that somebody might know of a cable from some other vehicle that would work perfectly for my conversion. I'll let you know what I come up with.
sierraben
21
Apr 17, 2006 05:37 PM
ddrumman2004
17
Feb 2, 2006 01:45 PM
sierraben
Mar 29, 2005 05:53 PM
cjben
Feb 22, 2005 07:23 PM
cjben
23
Sep 9, 2004 08:32 AM
