All was well until Friday night....
05 6.0 it has 169k miles on the truck, this past winter the truck started to run VERY VERY rough and took for freakin ever to start in the morning even if it was plugged in over night, It would buck very badly also even when it eventually warmed up!
So once the weather broke I replaced both fuel filters, flushed and refilled coolant w/filter according to a post I read on here about how to flush coolant system properly! Oil change, Glow plugs and harnesses.
Once that was complete the truck ran worse than before.... after driving it for a while and listening to the truck I came to the conclusion that an injector was bad or failing simply because it felt like it while driving / listening to it idle and how it preformed under normal driving circumstances.
oil temps were upwards of 235 deg I bought a rebuild kit for injectors and a bulletproof oil cooler , spent the better part of last week installing it after work.
After the work was done the truck started up and sounded and drove like a brand new truck.. i mean i bought the truck used and it responded better, had more power and just over all better than when I had purchased the truck.
Friday I drove it to work as i normally do, and when i went to leave from work it would not start ( 3rd day of driving after upgrade / rebuild ).
I see puffs of black smoke as it turns over but no joy on starting, It would not fire when I tried a little bump of starting fluid either.. I assume the GPCM has failed.. the glow plugs are an upgrade and burn 100 Deg hotter than OEM my assumption is that the bucking was caused by the original glow plugs failing, but in hindsight I now think its due to the failing / failed glow plug control module..
Dash light comes on for glows tho.. is there a definitive test i can do with an ohm meter that will tell me if the GPCM is in fact the cause ?
I tried taking unplugging the black plug on the GPCM and using the ohm meter to pink/grey wire connector on black plug to neg battery side getting an ohm reading of 1.0 to 0.9 ohm I was told if the reading was 2.0 to 0.5 ohm than the GPCM was in need of replacement. Is this the correct way to test it ? I do not have access to another GPCM and I do not want to spend any more money than i have to.
The FCIM Voltage says ( on livewire screen ) its steady at 48v trough startup ( when it started ) once in a while it would drop to 47.5v so I assume this is with in spec.
Thanks in advance for any input / solutions I appreciate all you guys do here and if it weren't for reading these forums than I would never have bought this truck and enjoyed owning so much!
Just for clarification: It seems that you're under the assumption that the glow plugs act like spark plugs and that's not the case. The glow plugs can stay on for up to 2 minutes when you start the truck depending on certain temperature parameters. After that the truck burns the diesel by compression. If it's warm enough you could probably start the truck without them.
And PLEASE don't use starting fluid. It can cause catastrophic engine damage on modern glowplug engine. I
Would I be wrong to assume that the glow plugs are not creating the heat necessary to aid in combustion at start up in 50deg weather ?
what temps would u not need the glow plugs to start ?
how do I test the GPCM
if its not the GPCM what else could it be to go from running at 5am to not running at 5pm ?
Thanks for the input thus far guys I really appreciate it!
Will post after I check these out in a few hrs.. damn the work day goes slow when you are with out your powerstroke!
The truck was running flawlessly for 3 days... then all of the sudden Friday after work it wouldn't start.
SCT showed the duty cycle for the ICP at 0.48 while cranking is that completely wrong ?
ICP reading said 1459 I thought that was a bit high
I have no other way to test out.. the SCT Livewire was saying .48 while cranking but the SGII said 1459 so I am pretty lost here
I cannot afford to replace anything unnecessary.If the correct reading I am getting is .48 then the Icp is bad, or the wiring has a short somewhere ?
