1978 - 1996 Big Bronco
no acceleration
Old Jul 6, 2003 | 11:58 PM
aggiebronco's Avatar
aggiebronco
no acceleration
i will be drive down the road and sopmetimes my truck will spit and studer. it happens alot when i have my light on or my sterio basses hard, when i roll up/down my windows, when my blinkers go on. just about anytime i use electric things on my truck. someone please help this is diving me crazy
Old Jul 7, 2003 | 12:56 AM
c96drumm's Avatar
c96drumm
no acceleration
Have you checked the battery terminal/cables for cleanliness and tightness? Only thing I can think of right now. And turn down that stereo.
Old Jul 7, 2003 | 10:29 AM
Kemicalburns's Avatar
Kemicalburns
no acceleration
get a bigger altinator and run the biggest cables from your battery you can. make sure you have a good ground to the motor as well.
later
Old Jul 7, 2003 | 12:59 PM
aggiebronco
no acceleration
are you sure that that is the problem, have you had this happen to you? thanks alot
Old Jul 7, 2003 | 01:07 PM
steve83's Avatar
steve83
no acceleration
Test the ignition system per the Haynes manual, and check those battery terminals.
Old Jul 7, 2003 | 01:27 PM
Kemicalburns
no acceleration
if its spitting and spuddering while driving when you turn the stereo on or use other electric devices its because there isnt enough spark getting to the plugs. if the alt isnt generating enough electricity that is what will happen.
Old Jul 7, 2003 | 05:24 PM
aggiebronco
no acceleration
the alt is good, i had it looked at today and it looks like the wiring harness going to the coil is bad. has anyone ever rebuilt one of these what kinda connections would you recommend. they dont carry them at ford anymore so i think i am going to have to make one.
Old Jul 7, 2003 | 05:26 PM
Kemicalburns
no acceleration
have you checked out the local junkyards, one from a bronco or truck would work im sure. im no electrician so i tend to stray from wiring .
Old Jul 7, 2003 | 05:27 PM
aggiebronco
no acceleration
i went but they did have any good ones
Old Jul 7, 2003 | 08:13 PM
aggiebronco
no acceleration
i am sorry i meant they didnt have any good ones
Old Jul 7, 2003 | 11:27 PM
steve83's Avatar
steve83
no acceleration
With a Haynes manual, you should be able to repair yours to perfect working order, even if it LOOKS like a ratnest.
Old Jul 8, 2003 | 10:41 PM
aggiebronco
no acceleration
i rebuilt the wiring harness today and it didnt help, i noticed that the voltage on my coil was 7.5 and the connector was 12-12.5 when it was not connected can someone please tell me what this means
Old Jul 9, 2003 | 01:19 PM
steve83's Avatar
steve83
no acceleration
High resistance somewhere between the battery and the coil, most likely at the ignition switch or one of your repairs.
