1978 - 1996 Big Bronco
horn dead
Old Jul 9, 2003 | 01:05 PM
Zukster's Avatar
Zukster
horn dead
quick question...88 XLT with the dual horns. Took them off and had them tested...bad. Each horn has a single wire connection and I am guessing that where it attaches to the frame is the ground. Do I need to get the replacement dual set-up at the local Autozone/Advance or do I need to get one high and one low? The only problem with that is there are two wire attachments on each of those. Unless I hook up the pos. end on each horn and run the neg. on each to the bolt that attaches the horns to the frame. I just don't want to make several trips to the salvage yard for a questionable horn for just about the same price. Any help? thanks
Old Jul 9, 2003 | 01:30 PM
steve83's Avatar
steve83
horn dead
Yes, the mounting bolt is the ground for the stock horns, and you should just ground one terminal on each of the aftermarket ones, if that's what you get. They should have direct-replacement horns with 1 wire each, though.
mikeo0o0o0
23
Apr 14, 2018 08:47 PM
PhilcoPGM
Dec 7, 2010 07:44 PM
betrayz
Jan 4, 2008 06:39 PM
jdmak68
Dec 13, 2007 09:09 AM
johninraleigh
Jan 16, 2007 04:11 AM
