Solid vs. Dual Mass Flywheel
Old May 22, 2014 | 12:52 PM
bluemtn95ford's Avatar
bluemtn95ford
Well I'm running at higher rpms and not getting the response from the truck. When I downshift there is a delayed response from the motor and no immediate "jump" in rpms. It's not hard to get in gear except sometimes into first from a higher gear. No grinding just minor resistance from the stick when downshifting into first. Never really bothered me and I never have to fight it much.
Thanks for the info Brad
Old May 22, 2014 | 07:23 PM
occupant's Avatar
occupant
typical ZF5 IMHO...we did the single mass flywheel change at 252K on our IDI rollback and it only made it noisier coasting in low gears...trans was done soon after at 260K...I do NOT think the flywheel change caused the issue as it was dry when they pulled it, a driver took it out of town for a tow and did not pay attention to the trans noise and locked it up
Old May 25, 2014 | 03:56 PM
bluemtn95ford
So your opinion is stick with the DMF?
Old May 26, 2014 | 06:49 AM
Diesel_Brad's Avatar
Diesel_Brad
No No No. Not unless you want a broken bell housing/ transmission housing
Old May 26, 2014 | 04:40 PM
bluemtn95ford
Okay well what you're saying is agreeing with a lot of the research I've read. Sounds like the Valair SMF kits next in line.
Old Jun 15, 2015 | 07:20 PM
96F250SD's Avatar
96F250SD
I did the conversion and put about 200 miles on it now. Much much easier to push down too.
Old Jun 15, 2015 | 08:08 PM
Birken Vogt's Avatar
Birken Vogt
FWIW I did this on my 97 Powerstoke with LuK as I recall about 100,000 miles ago and it was better in every way except the gear noise at low RPM. I pay no attention to it and let it growl but mostly try to keep the RPM up when possible. It has served me very well over all these years.
Talan
Feb 2, 2016 07:24 AM
264WSM
Jul 4, 2015 08:42 PM
jgavac
Dec 20, 2012 09:02 AM
seizure911
Mar 5, 2006 09:24 PM
wormy1433
Feb 10, 2006 10:41 PM
