Looking at a HID conversion kit, could use some help
Old May 18, 2014 | 11:30 PM
indirectinjection's Avatar
indirectinjection
I've been thinking of doing the same. My lights are dim and fogged, makes it hard to see on dark, rainy nights.
Not meaning to derail this but while looking at headlights on ProTuningLab, the lights look exactly like those from CP trucks. Not only smoked but the "black" and "clear" ? Anyone know what's up?
HID Xenon + 92-96 Ford Bronco / F150 / F250 / F350 Crystal Headlights Set - Smoked
OBS Ford Headlight 6 piece kit, Smoked
And from PTL, you get HIDs as well for cheaper than just headlights at CP. Are these really the same lights?
Old May 18, 2014 | 11:37 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I have no idea, none of them seem to give a brand, hard to tell if theyre better or just marked up. Think i decided on the "black" ones from tuner lab. Then if the halogens give me problems, ill go LED
Old May 19, 2014 | 03:49 PM
Rovernut's Avatar
Rovernut
First step to better lights is to upgrade your wiring with relays and 12ga wire, including the ground.
Old May 19, 2014 | 07:31 PM
FordTruckfan89's Avatar
FordTruckfan89
HIDs in a reflector not meant for them is a nuisance to other drivers, and has little actual improvement, some good +30 halogen bulbs (clear, no tint) , a good relay harness, and clean headlight lenses( restored or new) will give exceptional results. I was considering projectors and hids for mine, but with those three things changed, my headlight now meet my expectations. Look up Daniel Stern lighting If you want some more information.
Old May 20, 2014 | 04:57 AM
Rovernut's Avatar
Rovernut
Originally Posted by FordTruckfan89
HIDs in a reflector not meant for them is a nuisance to other drivers...
Not to mention illegal.
x2 on Daniel Stern. A lot of good information there.
Old May 20, 2014 | 12:41 PM
hairyboxnoogle
Well this is getting irksome... been trying to get ahold of protunerlab for 3-4 days now and nothing back... Might end up paying more through the other place linked here just to get them.
Old May 20, 2014 | 04:57 PM
SEH43's Avatar
SEH43
I have had HID on several of my cars. I found the quality of the lens is more important than the wattage of the bulb. Good lenses will put the light where you need it and keep it out of oncoming drivers eyes.
Old May 21, 2014 | 01:08 PM
bluemtn95ford's Avatar
bluemtn95ford
If you want to do HID's right you'll need to cough up the extra dough for some retro projectors. It's about the only way to get the quality you want out of your HID's.
Bi-xenon Morimoto Mini Stage III Kit (H1)
If you go this route, you'll have to spend the time and effort to get the projectors to fit the headlight housing. Heres the link to the guy who's done it.
https://www.ford-trucks.com/forums/1...-retrofit.html
They look bada$$ when done and do there job but they are a bit more expensive. But if you want it done right this is the way I'd go..
Hope this helps
xc4jokestomper
20
Jul 15, 2012 08:20 PM
YoungFordAddict66
24
Jan 12, 2011 09:46 AM
snowdog79
2004 - 2008 F150
Dec 14, 2010 08:08 PM
F-250 Super Duty
Aug 22, 2010 10:20 PM
JohnnyAirtime
Oct 12, 2009 10:49 AM
