Man vs. Ball Joint
Old Sep 1, 2014 | 11:18 AM
RedTaurus94's Avatar
RedTaurus94
No, I originally pressed a new ball joint into the factory upper arm. I know all that stuff was installed correctly as I re-checked it several times. I used the ball joint press I rented from O'Reilly and the top ones were really a piece of cake compared to the lowers.
Now, I've raised it up, removed the tire and I can see that the upper joint is loose inside the hole in the arm. It looks like the ball joint and the hole in the arm are both damaged. I've sent my wife to O'Reilly to get a new control arm/ball joint combo. Now I just hope I can get it apart easily....
Old Sep 1, 2014 | 11:39 AM
senix's Avatar
senix
I should come off of there pretty easy. My guess is you got a defective ball joint. Keep it and maybe you can at least get some money back for that.
Old Sep 1, 2014 | 06:34 PM
RedTaurus94
OK, got it fixed. Replaced the factory upper control arm, which had a somewhat wallowed-out hole, with the new upper control arm/ball joint combination. Here are a couple images of the old and new:
Now I've got to get the Ex back to the line-up shop! Thanks for the help, senix!
Old Sep 1, 2014 | 06:55 PM
senix's Avatar
senix
I got lucky and didn't need an alignment on mine.
Guess the moral here us to replace the upper with control arm as a standard practice
Old Sep 1, 2014 | 07:04 PM
RedTaurus94
Well, before tackling the original job, I read MANY comments that said you couldn't replace JUST the ball joint in the upper control arm. But I also read quite a few that said it could be done. O'Reilly sold me JUST the ball joint, so they must've thought it was do-able. I really liked the looks of the replacement upper arm I put on there today. If it was free and easier, I'd definitely do the passenger side too. Two things that worry me now: 1. I did the other side the exact same way. 2. I'd like to get my money back on the ball joint that came out.
Old Dec 19, 2014 | 06:42 PM
KsCop's Avatar
KsCop
It's an older thread, but I thought I'd add some information.
It's a common issue for the upper control arm 'hole' for the ball joint to get a little messed up. It will cause the new ball joint to be loose and 'pop out' like what happened here.
Moog Problem Solver line has an over-sized ball joint to fix this problem. The alternative, as was done here, is to replace the entire control arm.
Just adding on..
Old Dec 19, 2014 | 07:36 PM
senix's Avatar
senix
That is an idea. Thanks for the contribution.
delano0512
Oct 24, 2012 08:38 AM
stang3O2
1997 - 2003 F150
Feb 25, 2009 09:39 PM
thecheat508
1983 - 2012 Ranger & B-Series
Sep 30, 2006 09:29 AM
soahnk
Sep 21, 2005 10:02 PM
elk
Aug 6, 2002 02:37 PM
