Turbo
Old May 17, 2014 | 04:53 PM
Dan Ford 6.0's Avatar
Dan Ford 6.0
Turbo
I replaced my turbo. 2003 f250 6.0. Was frozen. Truck starts but still blows smoke. Dose not like higher rpms. Not sure why. Maybe it is what caused the turbo to go bad? Any ideas?
Old May 17, 2014 | 07:10 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Are you sure oil is coming out of the turbo oil supply line?
If the previous turbo had a blown oil seal, it can take a while for the residue to burn out of the exhaust pipe.
Josh
Old May 17, 2014 | 07:41 PM
Dan Ford 6.0
I have not checked to see if there is oil coming through the oil supply line yet.
I've run the engine for more than 10 minutes so it should be feeding now, unless the line is clogged and that is why the turbo froze in the first place. I'm not sure the best way to test that. Maybe remove fuse for fuel pump, turn engine over with oil feed disconnected. See if oil comes out?
Old May 19, 2014 | 03:22 PM
RA31925's Avatar
RA31925
What color's the smoke? Blue or black?
Old May 19, 2014 | 03:41 PM
Dan Ford 6.0
The smoke is blue
Old May 19, 2014 | 04:28 PM
73fan's Avatar
73fan
If you want to remove a fuse, maybe pull the FICM fuse.
Old May 19, 2014 | 04:30 PM
73fan's Avatar
73fan
The smoke is blue
Does the smoke smell of diesel or oil?
Old May 19, 2014 | 09:36 PM
RA31925's Avatar
RA31925
The smoke is blue
Sounds like oil to me.
Old May 20, 2014 | 12:07 AM
73fan's Avatar
73fan
Thing is, sometimes partially burned diesel has blue smoke too. We've probably all seen it on some dmax some time.
Old May 20, 2014 | 12:58 PM
RA31925's Avatar
RA31925
I've seen it look white (from a bad injector), but I don't think blue. I'll keep a closer eye on the Duramaxes though.
Pastor Jared Parmley
Jun 8, 2019 10:34 AM
sand1
Mar 6, 2013 11:12 PM
Kstar9
Jul 15, 2012 12:28 PM
noshow
Dec 6, 2010 03:37 PM
KyleG
Feb 9, 2009 01:06 PM
