fuel pressure?
Old Jul 29, 2003 | 10:56 PM
jvicars4's Avatar
jvicars4
fuel pressure?
i am finalize a minor rebuild on a 87 460. New holly 750 dp, intake manifold, cam, etc. I replaced the fuel pump coming from the fuel tank. I now need to replace the fuel pressure regulator. How much fuel pressure should i have coming into the carb. the 460 is in a 27 ft motorhome. thanks.
jamie
Old Aug 1, 2003 | 12:04 AM
airharley's Avatar
airharley
fuel pressure?
3-7 psi depending on flow requirements. I would have to say you'd be better off running 6-7 psi since you have the 750 DP.
