Hope this ignition module will work
Old May 17, 2014 | 01:10 PM
JEFFFAFA's Avatar
JEFFFAFA
NOTE. The B7A12106A cap took 7MM plug wires. Ford came out with the Blue D5AZ12106A cap because of the electronic ignition's 8 MM plug wires. 8MM won't fit iN the B7A12106A.
Old May 17, 2014 | 01:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hmm, well that I didn't know.
But, B7A-12106-A was used in 1974 with or without DuraSpark, which means that 1975/76 not only used a different cap, but different plug wires as well.
Old May 17, 2014 | 02:32 PM
JEFFFAFA's Avatar
JEFFFAFA
Yeppir. And also remember the year specific D4AZ12A199C ignition module? 1974 was an introduction/***stard year.
Old May 17, 2014 | 03:54 PM
Ford_Six's Avatar
Ford_Six
Google says the 1261 should fit your truck.
If it's a regular miss, though, it is most likely further down the ignition line than the distributor. It is more likely a bad cap, wire, or spark plug if a compression test shows them all to be even.
I have installed Pertronix ignitors before with stock coils, I just go back under the dash and tap into the pink wire as close as I can get to the ignition plug. That wire is a resistor, and it takes the whole length from the plug to the firewall to drop the voltage to 7v. Close to the ignition plug it's not much of a drop at all.
Old May 17, 2014 | 08:34 PM
hillcountryflt's Avatar
hillcountryflt
Installed the 1261 module today. Talk about an idiot. Got it wired. It cranked and cranked but no start. Seems you need the rotor as well. Such a dunce. Started right up. No change in performance as most predicted. But I was too tired to start further troubleshooting:
1. Clean out fuel lines;
2. check fuel filter;
3. check fuel flow;
4. compression tests.
Old May 19, 2014 | 02:23 PM
JEFFFAFA's Avatar
JEFFFAFA
3. check fuel flow;
Note. If the 1st (dry) compression test comes back with low numbers then perform a wet compression test to see if the numbers jump up. A couple of healthy squirts of engine oil in the spark plug hole just before you check that cylinder will temporarily seal the rings. If the low numbers jump the problem is in the rings. If they stay low the problem is in the heads.
Old May 19, 2014 | 02:40 PM
hillcountryflt
I was reading the Ford Service Manual when I came across a reference to the dry vs. wet approach. Additionally, it stated I needed the truck warmed up prior to conducting the tests.
Old May 19, 2014 | 02:50 PM
JEFFFAFA's Avatar
JEFFFAFA
And throttle open.
Old May 19, 2014 | 04:05 PM
trozei's Avatar
trozei
And throttle open.
How would that help?
Old May 19, 2014 | 04:23 PM
JEFFFAFA's Avatar
JEFFFAFA
Will give a more accuraute reading. The rings etc not sucking on the bottom of the throttle plates of the carb. More open to atmosphere.
Old May 19, 2014 | 04:47 PM
Tedster9's Avatar
Tedster9
And all spark plugs removed, run test at least twice, take highest reading, charge battery up between tests, etc. the idea is a standard, accurate test. In my old Motors manual, compression testing is on page 2. They point out if the engine is trashed there's no reason to investigate further or throw parts at it.
For all that, if an engine will run, a vacuum gage is a heck of a lot easier and good compression can be inferred pretty well from a normal reading.
Old May 19, 2014 | 07:33 PM
orich's Avatar
orich
If all your spark plug have a light tan and all look like this that's a pretty good indication It's still in pretty good condition.
If one or more cylinders are oily could be a bad intake manifold gasket if it's by these cylinders 3&4 or 6&7. and or bad valve guilds sucking oil.
If flat black carbon build up then may have a burnt valve seat.
Any of these conditions which can all be corrected with out pulling the motor.
Orich
Jghake
Feb 28, 2019 05:04 PM
Roller150
Apr 25, 2011 11:25 PM
compman
Jun 28, 2008 03:55 AM
slider00200
Jul 15, 2005 06:19 AM
f100guy
Nov 28, 2004 07:25 PM
