lights etc dimming while engine running.
Old May 15, 2014 | 10:10 PM
SteveRocket's Avatar
SteveRocket
I have a 1983 E350 RV with a 460 engine. It would appear that many "Mechanics" have altered the wiring in different ways. That being said I think the charging and starting electrics are fairly untouched. My issue is that once it has been running for a while the interior lights start to fluctuate so does the radio display. The AC fan speeds up and slows down and I feel like there is not enough gas being pumped up too due to some coughing and sputtering. When I press the brakes the radio stops playing and if I have the AC on it gets worse. Today I changed the voltage regulator and it made no difference. This vehicle has two batteries, one for starting the van like normal and one to run the coach part. The alternator charges both. Any thoughts and ideas would be helpful as I think it must be a bad ground somewhere but not sure where to start.
Old May 16, 2014 | 02:55 PM
Franklin2's Avatar
Franklin2
These vans are hard to work on. On the trucks they always ran a ground wire from one of the bellhousing bolts to the firewall for grounding. I don't know where they put it on the chassis vans, but if you want to experiment, get a scrap piece of wire, hook it to the starting battery negative and then stick it under a bolt that is grounded to the cab sheetmetal. See if you can find one under the dash or somewhere convienent and make sure there is no paint to block the elec path. See if that makes the problem go away.
Old May 16, 2014 | 03:43 PM
SteveRocket
thanks I think this may take some time
phillips91
Escape & Escape Hybrid
Aug 8, 2018 06:00 PM
Littlejon
Feb 21, 2012 02:42 PM
tje2015
Jan 18, 2012 09:53 PM
st8yd
16
Oct 5, 2008 07:22 PM
