Lights = Not Bright
Old Jan 18, 2012 | 07:15 PM
tje2015's Avatar
tje2015
Lights = Not Bright
Just curious is there a way to make my lights brighter - by like...ALOT!? These things barely allow me to see the damn road and the high beams are hardly noticeable. The lenses seem pretty clean - Even the orange lights on the roof of the cab are a little dim - the alternator seems like its doing pretty good too seems like its charging the batteries as good as its suppose too.
Should i just replace the bulbs with something a little more powerful?
Any suggestions?
Old Jan 18, 2012 | 07:25 PM
91dirtydiesel's Avatar
91dirtydiesel
Some info here might help
https://www.ford-trucks.com/forums/1...t-upgrade.html
Old Jan 18, 2012 | 07:43 PM
artfd's Avatar
artfd
Exclamation
Get a cheap multimeter and measure the voltage your truck is running with while you have the lights on & are going down the road. You don't need to install a dash voltmeter (although that would be nice), just wire the multimeter to hot & ground inside the cab, you can even do this through your cigarette lighter plug.
Modern alternators will charge the system at 14.5 VDC or so while you are doing this while older design alternators will charge at maybe just enough to keep the batteries from discharging -- you will see the results as dim bulbs. There are other reasons for dim lighting, but low supply voltage is important to consider.
Old Jan 18, 2012 | 09:53 PM
f350dualie's Avatar
f350dualie
reground your truck
take the ground off the block and clean then reinstall
also make new grounds from the battery to the chassis in at least two places and the engine to the chassis in two places
make sure you grind down to bare shiny metal then hook up grounds and paint over them to seal them tight
you would not believe how many stupid little problems can be related to a bad ground
SixGunCaliforniaKid
Dec 7, 2011 11:07 AM
ford-harto3457
Apr 1, 2009 11:00 PM
891/2ton
Sep 7, 2006 11:05 AM
epos48
Apr 28, 2006 07:06 PM
drumlinecowboy
Mar 23, 2005 04:36 PM
