Working on rear end
Old May 15, 2014 | 12:05 PM
conoso's Avatar
conoso
Working on rear end
Ok I'm on my highboy that's been parked for about a year. I knew I had brake problems and pulled both axles and drums. I decided to clean the diff cover at work with the sandblast cabinet. And I found the tag under all the grease and junk. I've look on the web and haven't had much luck ID the number. The numbers are 4 10 D5TA-LEB 603583 12 1 S
Old May 15, 2014 | 03:22 PM
B.Petry's Avatar
B.Petry
Ford Rear Axle Assembly Identification - Page 01 - FORDification.com
That should help you.
Old May 15, 2014 | 03:27 PM
lafermedavid's Avatar
lafermedavid
highboy
4:10 gears dana 60,,,your ring gear thats exposed now,that the cover is off also has gear ratio stamped in,,,,you can pull your axles and count spline flutes.Some 16,Some 30,,worth doing when your getting into your truck.
BIGTENN
Aug 18, 2009 08:40 PM
Pfeifferj
Apr 7, 2008 03:35 AM
Turgid77
Aug 26, 2004 02:45 PM
81fordf-100
Apr 14, 2004 04:03 PM
78blueford
Mar 25, 2003 09:06 PM
