1978 - 1996 Big Bronco
Excessive Wind Noise
Old Jul 6, 2003 | 08:43 PM
pyro515's Avatar
pyro515
I have a 94 EB Bronco that sees allot of highway driving. I noticed that there is an excessive amount of wind noise coming from the A pillar when I am cruising at around 65-70. I was thinking about replacing the weatherstripping around the doors. Do you guys know if this will help? Could I add more weatherstripping? Do you guys have any other ideas?
Thanks,
Mike
Old Jul 7, 2003 | 12:28 AM
mrwizard's Avatar
mrwizard
New weatherstripping might help, but I bet your door is either out of adjustment a little or the hinges are starting to sag.
Old Jul 7, 2003 | 06:04 AM
pyro515's Avatar
pyro515
What can I do to fix this then? If the hinges are sagging do I replace the hinges or is there another remedy?
Thanks for your help
Mike
Old Jul 7, 2003 | 07:47 AM
AlM's Avatar
AlM
yo,
Have you tried adjusting the hinges?
Look here for info and Tim has more info:
http://www.superford.org/registry/ve...s=9474#content
Also, Ford has a TSB on the w/s side door noise:
it's in my web page under Technical; Body
Old Jul 7, 2003 | 10:35 AM
pyro515's Avatar
pyro515
Great!! Thanks for the info. I will look at the hinges when I get home tonite.
Thanks,
Mike
truckmonger1
May 13, 2010 09:41 AM
straightaxle
Feb 14, 2010 06:08 PM
pdmoney
Nov 21, 2009 07:13 PM
460Gene
Appearance & Dress-Up
Sep 15, 2002 06:25 PM
dustman600
16
Jan 9, 2002 09:44 PM
