1978 - 1996 Big Bronco
91 engine/tranny options ?
Old Jul 6, 2003 | 02:14 PM
niva's Avatar
niva
Unhappy 91 engine/tranny options ?
Hi
I just found this site and it looks great!
I am having problems with my 91 bronco, 302-e40d. I have rebuilt this tranny twice and fear that I am looking at a 3rd time soon. I have been told I cant swap out this tranny as the engine and the tranny run off of one another. Is this correct?
After being told this I figured I would swap to a carburated 351 c6 combo. When talking to a mechanic about this he said it would not pass the e test with this combo.
Has anyone else out there run into these problems? I am not opposed to changing engine as mine is starting to get very tired. If anyone could offer any opinions or advice it would be greatly appreciated.
Thanks
Sean
Old Jul 6, 2003 | 06:13 PM
mrwizard's Avatar
mrwizard
If you want to put in a non-computer controlled tranny, just get a computer from a Bronco (or truck) with a manual transmission.
Old Jul 7, 2003 | 10:35 AM
Kemicalburns's Avatar
Kemicalburns
you could swap in an AOD with no problem. just like wizard said find a bronco/truck with a manual tranny and nab the computer just make sure it has same engine as yours and you will be fine.
best of luck
later
Old Jul 7, 2003 | 10:53 AM
niva's Avatar
niva
Thanks for the replies. I think I am going to look for a decent parts truck, and change the motor and tranny. Is the aod considered to be more reliable then the e40d? I have never been happy with the e40d. Any recomendations on going standered?
Thanks
Sean
Old Jul 7, 2003 | 11:09 AM
Kemicalburns
well the e4od is computer controlled, personally its one more issue that will get you stuck on the trail. sure it might be stronger but its way cheaper to get rebuilt and you can get it built just as strong for a good price. a local shop in my area wanted 1500 for a strong rebuilt aod that would handle 500lbs of torque. not to bad if you ask me.
later
darknight
25
Jul 9, 2012 11:06 PM
bliss1
19
Sep 9, 2008 10:55 PM
Georgia Mike
15
Jul 5, 2006 03:04 AM
jd_boggs
Apr 10, 2005 06:38 PM
Qvan666
Dec 8, 2003 05:12 PM
