Transmission Leak
Old May 14, 2014 | 10:39 AM
Boilerred73's Avatar
Boilerred73
Transmission Leak
I have an aftermarket transmission dip stick, that I bought from LMC. It is pretty much a piece of ****, but its shiny so they charge an arm and a leg for it. My issue is, it is leaking fluid around the opening for dipstick. Has anyone had this issue? I have messed with it several time to try and stop the leak but have had no luck.
My next step was gonna be to either change the "o" ring on the dipstick housing or put a little rtv on it, let it setup partially and insert it. The latter scares me because I dont want any rtv getting loose in there and clog the valve body.
Any thoughts? thanks for your help as always.
Old May 14, 2014 | 05:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Change the O-ring. If that doesn't work you can try the RTV but I'm not a big fan of using it in this application.
If any excess silicone gets into the tranny sump, the filter should catch it, just don't get carried away and use a half a tube.
Old May 14, 2014 | 06:19 PM
F350SuperCab4x4's Avatar
F350SuperCab4x4
i always put 2 O rings on and a light coat of RTV. never had a leak or problem with the trany sucking up the RTV. i also have a softail Harley and the dipstick has one O ring but there is 3 ridges in the cap so i put 3 rings on. it's really tight and Never leaks either. no RTV on the harley
CousinCarl
108
Dec 20, 2020 05:53 PM
LDP
Jul 17, 2012 07:35 AM
Shattered
Jun 11, 2012 12:44 PM
BigNiner19
6.4L Power Stroke Diesel
Feb 13, 2012 09:37 AM
