2010 F150 Radio Problems
Welcome to the forum! I'm part of the In-Vehicle Technology team so I can help you out. Like KJ Smith asked, are you trying to use the steering wheel controls or the touchscreen?
Which steering wheel controls aren't working? Please provide me the details, along with your model year and if your truck is equipped with a touchscreen.
Jaclyn
Top 4 buttons will control the wrong things.
For instance, the up volume will change stations, the down volume will turn the volume up ect.
If I remember and hit the volume down first..... things generally do as they are supposed to.
Truck was put in service 12/24/12.. has apx 45500 miles.
Mine is having issues from manual control, and I can change the station on steering control, but cant turn down volume. None of the manuel controls to anything worked. I went got into my truck around lunch to go eat, and all the controls are now working just fine.
2013 Platinum w/mft and Nav.
If you run into this issue again, give me a shout, and I'll look into it.
Jaclyn
I updated it last fall and checked for new versions last week.
I also did a master reset last week. No help.
I will pm you my VIN so you can check.
Thanks
Kevin
